DYNO Numbers for Baggers???
Old Oct 29, 2007 | 06:28 AM
  #591
Rev00's Avatar
Rev00
Default RE: DYNO Numbers for Baggers???
SGTPool, Badass rear fender too. Where did it come from? I can hardly see it, but did you use LED Light bars on the spacer panels for your turn / brake lights?
Old Oct 29, 2007 | 01:19 PM
  #592
NCCopBikeRider's Avatar
NCCopBikeRider
What wrong with this Dyno Chart?
06 Electra Glide 15,250 miles
FullSacTrue Dual Conversion
K&N 3909 A/C
Autolight 4164 Plugs
Stock ECM with Twin Scan II Data System
30 - 35 MPG
70 - 75 MPH Interstate Riding, 3000 RPM
Shift @ 2500 - 2750
Stock Wheels/Tires/Gearing
HP seems down for "Stock" bike as well as MPG
Seems to be lean at 3000 and very very rich every where else in the RPM Range
Any Thoughts
[IMG]local://upfiles/34704/BD2C51E954E541A3B583FC083E6DF256.jpg[/IMG]
Old Oct 29, 2007 | 05:33 PM
  #593
mattman22033's Avatar
mattman22033
No Devil Dawg did not do the tuning. At the time of the build they did not have a dyno. They do now though and they have a top notch tuner (Will Gilbert)...whoI consider one of the best, if not the best in Northern Virginia.
The original tuning was done by Skip's in Winchester and that is the graph you see. I have since had it re-tuned by Will but I do not have that graph.
ORIGINAL: dcfatboy
Did DDCC do the tuning? Can you post the graph?
[IMG]local://upfiles/43895/1D94790DCF08483FBD49C5AAEAE9C31D.jpg[/IMG]
Old Oct 29, 2007 | 09:25 PM
  #594
SGTPOOL's Avatar
SGTPOOL
The fender is from Native Custom Baggers. It's stretched 6" with the PYO shadow box welded in. The LED'S are flush mounted into the wings welded into the rear fender. The wings are molded into the upper strut covers. NCB does some awesome work. Thanks for looking!
Old Nov 3, 2007 | 09:47 PM
  #595
Artur's Avatar
Artur
Wish they had done a "before" so I could see what I gained...??
72.53 hp
82.67 tq
Old Nov 8, 2007 | 10:08 PM
  #596
jdseago's Avatar
jdseago
Stage I
Hello All im new to the Forum, here is my Dyno Info.
2007 Black Cherry and Pewter Silver Pearl Ultra Classic
Dyno July 07 @ San Jacinto Harley Davidson
77 HP-96 TQ
Power Commander III
SE intake
SE Cams
Reinhart Slipons
Old Nov 9, 2007 | 07:35 PM
  #597
myzen's Avatar
myzen
SE 95"
203 cams
no headwork
SERT
K&N airfilter
V&H True Duals
V&H Basic Slip-ons
79 HP/100 TQ
Old Nov 12, 2007 | 04:34 PM
  #598
nidan's Avatar
nidan
2007 FLHX Stage II 103/SERT / SE street perf slip-ons - no headwork.
Good enough for now .
[IMG]local://upfiles/14246/9329831538A84AC39744136CB989B0DB.jpg[/IMG]
Old Nov 12, 2007 | 07:08 PM
  #599
Hancock49's Avatar
Hancock49
Stage II
2002 FLHT
95 kit
Hot-Shot Heads
10.50 pistons
Hot-Shot HS-14 Cams
Daytona Twin Tec
Mikuni 42
Bassani 2 into 1
HP 103.6
Torque 102.4
SAE Smoothing 3
4th gear
Lynchburg ,VA Harley
(we can't upload the dynojet sheet)
Old Nov 13, 2007 | 05:41 PM
  #600
SMacDunk's Avatar
SMacDunk
Who's Will? I'm looking for a good shop/tuner in N. VA...
