Can not find what C 1095 error code mean???
Old Jun 1, 2008 | 09:34 PM
elpoman's Avatar
elpoman
Default Can not find what C 1095 error code mean???
I have an O8 ultra, and just checked my diagnostic trouble codes, and I get a code that is not on any list that I have seen. I get a C 1095 on the last letter on the dash witch is a small letter b witch is also not shown on any list. I have PSSPTb. Help.No check engine light
Old Jun 1, 2008 | 10:12 PM
questor's Avatar
questor
Default RE: Can not find what C 1095 error code mean???
Don't know if this is what you are looking for:
Date: 01/02/1997
Component Name: 036400 SERVICE BRAKES, HYDRAULIC:ANTILOCK:ABS WARNING LIGHT
NHTSA #: BC0251970201
SUMMARY: ABS INDICATOR ILLUMINATION WITH DTC C1095. *JD
http://www.diyautotech.com/technical...URY/1997/SABLE
Old Jun 1, 2008 | 10:15 PM
Dionicio's Avatar
Dionicio
FRONT BRAKE SWITCH OPEN.(C1095) See Page 6-47, 2008 Touring Diagnostics Manual for more info.
Old Aug 12, 2008 | 10:34 AM
08UC's Avatar
08UC
would this be located in the right handle bar switch area. i am getting this code along with po577. i have a check engine like and intermident cruise.
thanks
Old Jul 12, 2014 | 08:07 PM
Elcabito's Avatar
Elcabito
1st Gear
Default same issue with Streetglide 08.
I have the same problem with my 08 Streetglide, however no ABS light.
Old Jul 12, 2014 | 08:24 PM
Buckinfitch's Avatar
Buckinfitch
thanks
try toggling the cruise control on off switch quickly and if the light goes out ..then reset the code by holding the trip button in longer than 5 second, code will clear , could be your set/resume switch too, check connector/clean.
Old Jul 12, 2014 | 09:11 PM
Weavr99FLHT's Avatar
Weavr99FLHT
I had this list of the "C" codes saved - many lists of codes on the internet don't include these...
The following came from the ABS section of the 2008 Electrical Diagnostics manual-
C0562 Device voltage low
C0563 System voltage high
C1014 ECU internal fault
C1017 Pump motor power circuit open fault
C1018 Pump motor ground high resistance fault
C1021 Front wheel speed sensor equals 0
C1023 Rear wheel speed sensor equals 0
C1025 Front wheel speed signal intermittent
C1027 Rear wheel speed signal intermittent
C1032 Front wheel speed sensor circuit open or shorted
C1034 Rear wheel speed sensor circuit open or shorted
C1042 Pump motor open
C1043 Pump motor stalled
C1055 ECU internal fault
C1056 ECU internal fault
C1057 ECU internal fault
C1061 ECU internal fault
C1062 ECU internal fault
C1065 ECU internal fault
C1066 ECU internal fault
C1094 Front brake switch always on
C1095 Front brake switch open
C1118 ECU internal fault
C1121 ECU internal fault
C1151 Front wheel release too long
C1153 Rear wheel release too long
C1158 Calibration programming required
C1206 Wheel speed sensor frequency out of range
C1208 Wheel speed sensor frequency out of range
C1212 Front or rear brake not applied with decel
C1214 Rear brake switch always on
C1216 Rear brake switch open
Weavr99FLHT
Deleted... duplicate post
Old Jul 12, 2014 | 10:31 PM
FLHTCU Owner's Avatar
FLHTCU Owner
Might be the hydraulic brake light switch.
Twin88rk
Milwaukee Eight (M8)
17
Aug 26, 2019 10:05 AM
travln2
Sep 9, 2016 07:05 PM
Classic Rider
Mar 3, 2012 08:30 PM
mopar400
Mar 16, 2010 08:34 AM
TexasVet
Jan 9, 2009 09:33 AM
