Floorboard insert qestion???
Old Jun 10, 2008 | 04:11 PM
08HD's Avatar
08HD
Default Floorboard insert qestion???
I plan to install these and I was wondering if someone who has these can give me there opinion about these and how was the installation process
Old Jun 10, 2008 | 05:33 PM
bigskyhd's Avatar
bigskyhd
Default RE: Floorboard insert qestion???
Link WON"T pull up!
Old Jun 10, 2008 | 06:30 PM
hotshot's Avatar
hotshot
Try the link by clicking HERE !
That should work.... just helping out because I want to know about what others think about those floorboards and installation.
New '08 Ultra with no bling.
Old Jun 10, 2008 | 07:21 PM
Cannon00000's Avatar
Cannon00000
They are extremely simple.&nbsp\\; You will simply pull these old ones out and pop the new ones in.&nbsp\\;
They new ones will have small rubber nipples on the bottom. You will need to push these nipples through the holes in the floor board pan. This will hold the new covers in place.
WhaaLaa you are done.
Old Jun 10, 2008 | 10:31 PM
hotshot's Avatar
hotshot
cool beans, Cannon !&nbsp\\; Thanks !
Old Jun 10, 2008 | 10:43 PM
bigskyhd's Avatar
bigskyhd
Still can't pull up photo. &nbsp\\;
Old Jun 10, 2008 | 11:07 PM
Bikeman's Avatar
Bikeman
A little dish soap on the small rubber bumps also helps them slip through the floorboard pans. It's covered in the instructions that come with the inserts.
-Bikeman
Old Jun 11, 2008 | 10:47 AM
garyhendley's Avatar
garyhendley
i could not pull up the picture but the floorboards are easy just puch the
rubber **** thru the holes i used a small screwdriver took only a couple of minutes
Old Jun 11, 2008 | 12:24 PM
huffhuff's Avatar
huffhuff
lube them and use needle nose pliers to gently pull the rubber thru the holes.
Timpechos
Aug 5, 2014 11:25 PM
pococj
EVO
Mar 8, 2010 09:02 PM
robbie52
Aug 9, 2009 09:06 AM
ScooterGuitar
May 19, 2006 10:56 PM
ric
Feb 3, 2006 07:44 AM
