Fly By Wire
Old Jun 12, 2008 | 03:34 PM
  #31
Rocky Rox's Avatar
Rocky Rox
Default RE: Fly By Wire
My 08 RG has 3300 miles and the high idle has happened many times. MoCo thinks it's the ECM, not the FBW.
Old Jun 12, 2008 | 03:44 PM
  #32
snafu's Avatar
snafu
No problems with my TBW - '08 RKC with 7k miles
Old Jun 12, 2008 | 03:45 PM
  #33
rocknrod's Avatar
rocknrod
If you read, the 08's arent the only ones that&nbsp\\; have had this problem:
https://www.hdforums.com/m_1881965/tm.htm
&nbsp\\;
&nbsp\\;
Old Jun 12, 2008 | 05:10 PM
  #34
soon to be's Avatar
soon to be
ORIGINAL: sparks98
Never Mind
&nbsp\\;\\\\\\;\\\\\\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\;\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\ \\\\\\\\\\\\\\\\\\\\\\\;Thanks for your patience
damn, you were really hard on this newby (not a troll), he never had a chance!
Old Jun 12, 2008 | 06:44 PM
  #35
djdmad's Avatar
djdmad
Picked up 08 ultra&nbsp\\;10 days ago&nbsp\\;mine idles between 1300 and 1900. tried cycling the ignition on and off 4 times and that reduced idle to 1100 but only lasted about a day. with 1200 miles on the bike it still idles consistintly at 1900rpm.Getting 1000 mile service monday and will get this resolved&nbsp\\;at the dealer.&nbsp\\;
Old Jun 12, 2008 | 07:09 PM
  #36
dw2169's Avatar
dw2169
I have 3000+ miles on mine, the only probem was the throtte spring would not pull it back to the original position but leave it whereever you took your hand off, the dealer reduced the friction, lubed it some, and it has worked great ever since. I had the stage one done at a thousand miles with the HD download, bike runs great, the mileage is between 30 and 38 mpg depending on how I twist the throttle. Sure is fun though.&nbsp\\;
Old Jun 12, 2008 | 07:18 PM
  #37
george liles's Avatar
george liles
exactly right! I say take it easy just a little bit. There is some kind of reset on the switch being turned on and off 4 times to reset the throttle position. Dealer said that was my issue until I told them to hook the damn thing up and check a little further after I stalled it in a 4 lane road out in front leaving the dealer.
George
  #38
Trock's Avatar
Trock
The problem seems to be with people with low post counts. If cycling the ignition doesn't work try posting more
Old Jun 12, 2008 | 07:42 PM
  #39
rochkes's Avatar
rochkes
I guess I am one of the lucky ones. There was no getting used to it, it works exactly that same as the other dozen or so bikes I have had with throttle cables. 5,000 flawless miles. No delay in throttle response.
&nbsp\\;
I wouldn't go back to my '05 for anything less than a bigger stack of money than I have invested in my '08. Then I'd go out and buy another '08
&nbsp\\;
Dennis
Old Jun 12, 2008 | 07:59 PM
  #40
djdmad's Avatar
djdmad
how many post will it take to fix the throttle problem on the 08 ? let us know so we can start&nbsp\\;posting the required amount&nbsp\\;to finally fix this problem.
