Puff sound- from front pipe
Old Jun 19, 2008 | 12:09 PM
bucs012's Avatar
bucs012
Default Puff sound- from front pipe
I have noticed that sometimes when I hit he start button, but the bike does not start, I will get a "puff" from the front exhaust head area. Yesterday it also did this and died on me while sitting at a red light..........Also, if I am just sitting still and twist the throttle real quick, it sounds like a small puff from that same front area. What do you think could cause this?
&nbsp\\;
My bike has about 6 weeks left on warranty so I want to get it fixed if you think is something wrong. I know HD's make so many dang noises that it may just be normal??????
Old Jun 19, 2008 | 12:11 PM
garyhendley's Avatar
garyhendley
Default RE: Puff sound- from front pipe
take it back to the dealer while your warrenty is still good
Old Jun 19, 2008 | 12:14 PM
FX4 Level II's Avatar
FX4 Level II
Probably just compression being released. I was told with my 103" to start it to bump the start button first, it releases the pressure, then hit it again to start it after that. And you can hear and feel (if your standing behind the exhaust) the pressure being released.
Old Jun 19, 2008 | 12:50 PM
Geoff's Avatar
Geoff
Let the dealer look at it before the warranty expires. On the other hand, make sure the nuts that secure the pipe flange to the head are tight. Mine tend to loosen.&nbsp\\;
Old Jun 19, 2008 | 01:00 PM
stro1965's Avatar
stro1965
It's&nbsp\\;high compression caused when you try to start the bike while hot after just a short time off.&nbsp\\; Compression hasn't had time to leak down yet.&nbsp\\; My 88" never did it, my 96" does it regularly.&nbsp\\; Annoying.
&nbsp\\;
Old Jun 19, 2008 | 01:39 PM
winston chopper's Avatar
winston chopper
AC maybe. Thats makes a good puff at start up and shut down?
Header gasket leak?
Old Jun 19, 2008 | 03:23 PM
bucs012's Avatar
bucs012
ORIGINAL: winston chopper
Header gasket leak?
&nbsp\\;
I'm a little slow......What does AC mean? \\
Old Jun 19, 2008 | 03:42 PM
bagman1's Avatar
bagman1
AC= air cleaner. I have a 103 with 13k on it and never had any of these issues. Sounds like an exhaust leak. As mentioned ck the nuts and get to dealer before your out of the computer.
Old Jun 19, 2008 | 04:07 PM
winston chopper
Sorry dude, air cleaner.
Old Jun 19, 2008 | 05:07 PM
bucs012's Avatar
bucs012
&nbsp\\;
Thanks! I should have known that any way!
VRADMAN
Milwaukee Eight (M8)
24
Sep 8, 2018 09:10 PM
odie-in-az
Sep 29, 2012 11:16 AM
VINNIE JAMES
Jul 23, 2011 05:15 PM
SURFOR Chop
Apr 4, 2011 07:57 AM
flynavy
Jul 9, 2008 06:40 PM
