Antenna booster hookup...
Old Jul 7, 2008 | 07:25 PM
GMC4EVR's Avatar
GMC4EVR
Default Antenna booster hookup...
First off...I'm a noob...and I searched already but wasn't successful finding some&nbsp\\;\\\\\\;specific instructions and&nbsp\\;\\\\\\;pics...forgive me if it's already here...
&nbsp\\;\\\\\\;
I was given an AM/FM antenna signal booster.&nbsp\\;\\\\\\; It has a female receptacle for the OEM antenna wire, an antenna wire to go to the radio and a green wire with a female spade type terminal on the end.&nbsp\\;\\\\\\;
&nbsp\\;\\\\\\;
My question is...which wire should I hook up the green wire to inside the fairing...I want it to be switched 12v, but I am unsure...high rez pics and idiot proof instructions would be greatly appreciated!!!
&nbsp\\;\\\\\\;
I want to mount it inside the fairing to boost the signal of the new rubber antenna I mounted behind my saddlebag filler strips...
[IMG]local://upfiles/65892/B9604D7B7519469597063E46BA32887B.jpg[/IMG]
Old Jul 7, 2008 | 07:33 PM
DKSS07's Avatar
DKSS07
Default RE: Antenna booster hookup...
Welcome first of all. Without know anything about what you have, green is normally a ground. JMO.
Old Jul 7, 2008 | 07:42 PM
prc1333's Avatar
prc1333
Need more information. Green is normally ground, as DKSS07 said, however, in 12 volt audio, green can sometimes be switchable power, the antenna should ground itself. I tried to look up generic power boosters on the web, with no luck. I had a booster in a 1968 Dodge Charger, and I remember the instructions saying green is power, switched on, so it doesn't eat up the battery. For antennas the green might go to the radio power switch so it raises the antenna. You need to do a little research.
blueflht's Avatar
blueflht
if its an am fm booster the green wire should be hooked to the aux switch. hot lead. the ant lead is the ground
Old Jul 7, 2008 | 07:45 PM
GMC4EVR's Avatar
GMC4EVR
OK, cool.&nbsp\\; Sounds like I am humping up the correct legs...Is there&nbsp\\;an unused,&nbsp\\;switched +12v lead inside the fairing?&nbsp\\; If so, I will have a go at it tomorrow and post pics...I am hoping this is a cheap *** alternative to the ugly antenna issues...
Old Jul 7, 2008 | 07:55 PM
prc1333's Avatar
prc1333
Alright, then you need to find the aux switch. It goes to a cigarette lighter on my bike.
Old Jul 12, 2008 | 06:55 PM
GMC4EVR's Avatar
GMC4EVR
Thanks for all the info...even though the gift booster didn't work, I now know how to hook one up if I wanted to..
RidemyEVO
May 27, 2012 03:00 PM
Snappykevin
May 20, 2011 02:38 PM
05Fatty
Mar 16, 2008 04:38 PM
kayman
Mar 14, 2008 09:15 PM
JDean
Jun 17, 2006 04:43 PM
