slip on question
Old Mar 11, 2006 | 10:58 AM
roadkingcustom's Avatar
roadkingcustom
Default slip on question
I posted this in the exhaust section, but got no response. I have V&H slipon's on an 04 Road King Custom. I'm trying
to make it a little louder. A friend said I can remove the baffles and run a 1/4 bolt through the bottom of slip on to give
me some resistance. Anyone heard of doing this?
Michael
Old Mar 11, 2006 | 11:12 AM
HDF Tech's Avatar
HDF Tech
Default RE: slip on question
With a change in back pressure by removing baffles, you affect how the engine runs in the lower end of the range. You'll loose torque by reducing backpressure. It's a trade off that you have to weigh out for more noise. You should be able to modify (shorten) the baffles a bit to increase the sound without seriously affecting performance.
Old Mar 11, 2006 | 12:07 PM
100thRK's Avatar
100thRK
Baffle removing I have heard of but not the bolt. Hey I seen weirder things so, go for it!
Old Mar 11, 2006 | 12:23 PM
fignuton's Avatar
fignuton
I pulled the baffle out of my V&H duals one time. It was too loud and I noticed a loss of power/torque. Look on V&H website. They do not recommend removing the baffles. I also can't see how a screw is going to provide any amount of back pressure in comparison to a baffle.
StugotSOA
Exhaust System Topics
Apr 1, 2019 08:08 PM
cloudenbeck
Oct 15, 2012 11:11 PM
thelawnmowerman
Mar 24, 2011 03:17 PM
Crazy K38
Aug 30, 2010 03:55 PM
Chadookydo
Apr 29, 2008 09:05 PM
