speaker question
Old Aug 9, 2008 | 04:15 PM
Bad Pig's Avatar
Bad Pig
Question speaker question
ok, so my 02 has a factory 8 ohm set up. I have a pair of 4 ohm speakers. so as to not fry my radio i neeed to wire these in "series", but don't i lose "stereo" by doing that if i use only one chanel to do this? or is there another way of doing this to keep my left and right correct? this has been bugging the hell out of me. I done some research and it shows to wire the speakers using one chanel.
Old Aug 9, 2008 | 04:36 PM
ngoti8tor's Avatar
ngoti8tor
That doesn't sound correct. You should still wire them up using BOTH Left and Right channels.
Old Aug 9, 2008 | 04:38 PM
Ugly Troll's Avatar
Ugly Troll
BP, not really sure I understand the wiring dilemma you're having. Why not just take the wires from the 8 ohm and hook them to the 4 ohm? The only difference you're going to have is the 4 ohm will sound much better. There should be a place on the 4's to hook your 2 wires to just like on the 8's. No prob.
Old Aug 9, 2008 | 04:47 PM
Bad Pig's Avatar
Bad Pig
the speakers are already hooked up, was when i bought the bike, the problem is that after listening to the radio after about 30 mins the speakers start "cutting" out, seems like after it gets "hot". now this morning it was pretty cool and i had no issues, but when the weather gets warm the speakers start acting crazy driving me nuts. i don't want to spend the $'s on a new system yet. i've heard people say if you don't have the impedence right you can fry your radio or amp....am i right? the speakers are 4 ohms each and the stereo is supposedly rated 8 ohms. just affraid i might be "overheating" things,,,,lol hell i have no clue.
Old Aug 9, 2008 | 05:19 PM
blueflht's Avatar
blueflht
im not sure where you are getting your info from. an 02 nfactory sysstem has 4 ohm speakers and a 4 ohm radio i dont know of any harley setup that has 8 ohms
Old Aug 9, 2008 | 05:21 PM
blueflht's Avatar
blueflht
your speakers cutting out may be a wiring issue. check all connections. may also be a loose wire in thr head unit itself. radiosound in louisville ky does all the refurbs on the 05 and older radios
Old Aug 30, 2008 | 04:01 PM
deuce dude's Avatar
deuce dude
did you ever figure this out? i put in some speakers from my buddies 07 and mine started doing the same thing.....i suspect the ohms too...
Old Aug 30, 2008 | 04:20 PM
ironhead3fan's Avatar
ironhead3fan
From everything I have read on here, the RadioSound radios are 8 ohm, and the HK's are 2 ohm. Never ever heard 4 ohm until today.
How about this, I bought the 8 ohm speakers for my 03 from J&M and haven't had any issues whatsoever. Hope this helps.
Old Aug 30, 2008 | 04:44 PM
blueflht's Avatar
blueflht
bad pig. what about hitting firecap501 up for his arc amp? then the 4 ohm speakers wont be an issue and the sound will blow you away! its 1 upgrade you wont regret. tell him i sent you to him. check him out he is strate up and stand up bro!
Old Aug 31, 2008 | 01:40 PM
deuce dude's Avatar
deuce dude
thanks for the quick reply! i wonder if i can wire it up in series with the back to make it work? maybe both rights in series and both lefts?? the speakers sound good, hate to pull them.
badge502
Audio Systems
Sep 18, 2017 06:11 PM
hogwild229
Audio Systems
Mar 9, 2014 07:40 PM
Choppie
Audio Systems
Apr 2, 2013 12:44 AM
silverbullitt
Mar 18, 2012 10:35 PM
Mongo40
Jan 18, 2008 06:49 PM
