Slip-On Installation Question
Old Aug 20, 2008 | 10:54 AM
ponesma's Avatar
ponesma
Default Slip-On Installation Question
I know I asked this question a while back but since the upgrade I cant seem to find all my old posts, so please dont flame me.
I installed Hooker Tuned Flow Slip-Ons with a FuelMoto PCIII. Bike runs great, but I get a bit of popping out the exhaust on decel. I know I was told to put sealer on when I put the slip-on on when I asked before. Is there a specific type that I should be using, right now I dont have any but I want to get that done this weekend. Do I put the sealer in the head pipe then put the muffler on or do I put it on the muffler first? I will be getting new clamps also just to make sure they are good.
Thanks
Old Aug 20, 2008 | 11:50 AM
jerseyjeff62's Avatar
jerseyjeff62
hi temp silicone orange color
Old Aug 20, 2008 | 12:20 PM
iclick's Avatar
iclick
Thanks
I used new clamps and anti-sieze compound (Permatex). Apply it on both the muffler and pipe, then slip it on. I've no problems with decel popping, and I understand it is a function of air leakage around the mufflers, as you suggest. Jamie at Fuel Moto says other factors may be involved and that some pop, some don't.
The anti-sieze compound not only helps to seal, but keeps rust away making removal easier at a later date. Also, torque clamps to 60 lb/ft.
Old Aug 20, 2008 | 01:09 PM
ponesma's Avatar
ponesma
Is there a certain anti-seize for heat? I did talk to Jamie and he said that same thing, I just could not remember what type of sealer I had to use. He said to get that done and if it still pop's we will tweek the PCIII map. I want to stop by the parts store on my way home from work to pickup whatever I need. I was also told that it has to dry before starting it.
Old Aug 20, 2008 | 01:42 PM
atrox88's Avatar
atrox88
Dang, I kinda like the popping!
Old Aug 20, 2008 | 01:51 PM
fotoflojoe's Avatar
fotoflojoe
Hi-temp silicone. Run a bead inside the muffler, just beyond the split. Once seated, give the muffler a twist to spread silicone.
trnewman
Aug 29, 2012 06:46 PM
DeiGratia
Apr 27, 2012 10:38 PM
Ozzie Dave
Oct 10, 2009 08:00 PM
buzzard07
May 15, 2008 02:20 AM
ponesma
Jan 28, 2008 09:57 AM
