Handlebar installation
Old Oct 20, 2008 | 03:40 AM
ironhead3fan's Avatar
ironhead3fan
Bump for the morning crew.
Old Oct 20, 2008 | 10:11 AM
MassHD's Avatar
MassHD
Bump again
Old Oct 20, 2008 | 12:12 PM
07FLHRCMarinePatriot's Avatar
Check out my "how-to". It's for putting 16s on an 07 RKC, but should parallel most of what you gotta do.
https://www.hdforums.com/forum/touring-models/271781-a-how-to-guide-for-ape-install.html
Old Oct 20, 2008 | 12:14 PM
Bertk's Avatar
Bertk
Originally Posted by MassHD
Any tricks or tips on the internal wires?
I recently installed a set of Khrome Werks 300515 +2 Wide Sweeper bars on my 2008 Street Glide and ran the wire internally. Here a write-up on the process, along with these pics.
The service manual came in very handy. There is a section on the different wire connections. On the Street Glide all involved connectors were the Molex type.
Once the controls are removed from the old bars move them over to a work area along with the new bars. Make note of each wire location within the connector so they go back in the correct location. I took photos along with notes. Remove the wire ends from the connectors using the instruction in the service manual. Drop a string with a nut on the end down the bars until it comes out the opening in the bottom of bars. Drop two strings down the throttle side. One for the control wires and one for the sensor wires. Tape the string to the end of the wires and gently pull them through. I removed most of the sheathing protecting the bundle of wires. I left just enough at the control end so it could be fed a little way through the top hole in the bars at the controls. The sheathing left over can be slipped over the wires coming out the bottom of the bars and fed up to help protect the wires within the bars.
On the throttle side, I decided to replace the throttle grip sensor which eliminates the green connector. This helps when pulling the wires. The end result should look something like this. I connected the throttle grip sensor wires after the bars where installed.
Wire extensions were not needed but the connectors within the fairing had to be relocated and tied down. I spent about an hour rotating the bars while watching the wires to make sure there was no wires binding.
Take you time. The results are well worth it.
Old Oct 20, 2008 | 01:16 PM
Bertk's Avatar
Bertk
Originally Posted by crash12888
I just installed grip heaters on my 08UC and just used an air nozzle to blow the grip off.
Slid off like butta on a hot knife. Mitch
HD stopped using glue on the 2008's.
Old Oct 20, 2008 | 08:31 PM
ironhead3fan
Thanks for all of the responses. I don't think I will have any problems. I am getting the manual out this evening to get a head start on some of the procedures.
Old Oct 23, 2008 | 05:56 PM
ironhead3fan
OK, just got all the pieces to do this today. Now I read I have to take the exhaust off. Is there anyway just to loosen it to get the tranny cover off?
Old Oct 23, 2008 | 06:01 PM
sifularson's Avatar
sifularson
You have to pull the cover to change the clutch cable. The right side exhaust has to come off. Sorry.
Did it myself a couple months ago. No short cut I know of except for tipping the bike to avoid loosing too much trans oil.
Steve
Old Oct 23, 2008 | 08:44 PM
Bertk's Avatar
Bertk
Originally Posted by sifularson
I just went out to the shop to check on this. I bought a full Brembo set-up from a forum member to replace my 07 brakes. I was hoping to use Speedbleeders on them.
Damn . . . they are not the same size. The Brembo bleeders are built into the banjo bolt and they are a smaller size. They also have an 0-ring seal on them. They take a 3/8 wrench although the threads look metric. This would make sense that HD would have them make the "nut" a standard size.
Anyone know the thread size????
I'll have to do some research. Think I'll send an email to the Speedbleeder people and see what they have to say.
Stay tuned . . .
I emailed the folks a Speed Bleeder and the part number for the Brembo brakes is SB8125L. Received them in the mail yesterday and may install them tomorrow.
Old Oct 23, 2008 | 09:03 PM
Bertk's Avatar
Bertk
True duals can be swung out of the way. Stock exhaust requires the removal of the right side exhaust.
