2008 SG Front Wheel Removal?
Old Nov 22, 2008 | 09:52 AM
smokin's Avatar
smokin
Default 2008 SG Front Wheel Removal?
I picked up a set of factory brake rotors that I had polished and I want to take the front wheel off and put them on instead of the stock ones.
What is the short version of "how to"?
Do the brake Cal. need to come off first or can you slide the new wheel up into them?
Torque # on the front axle after I put it back in ?
No - I don't have the service manual for it yet - hope to get it for Christmas! But I'd like to get these swapped out over TGiving.
It's not a antilock model if that matters
thanks
Smokin'
Old Nov 22, 2008 | 10:01 AM
HDV-GLIDE's Avatar
HDV-GLIDE
thanks
Smokin'
The brake calibers have to come off or at least on one side to clear the wheel.
I would have to check my manual on torque but I'm sure someone will post it here before I get out into the garage....
Old Nov 22, 2008 | 10:24 AM
Trock's Avatar
Trock
Axle nut 60-65 ft-lbs axle cap nuts 132-180 in-lbs Caliper mounting screws 28-38 ft-lbs Rotors 16-24 lbs Make sure the spacers stay the way they came off and use anti seize on the axel
Old Nov 22, 2008 | 03:44 PM
n.o.yat's Avatar
n.o.yat
be shure to replace the bolts on your rotors when you put it back together
katanaplanet
May 21, 2015 02:05 AM
flynavy
May 3, 2011 02:07 PM
LFTD1
Jan 26, 2011 09:38 AM
wally09
Aug 20, 2010 07:19 PM
Rodney Wise
Feb 20, 2010 07:54 AM
