vibration in right floor board what did i do wrong
Old Nov 22, 2008 | 11:37 AM
lkr0's Avatar
lkr0
Default vibration in right floor board what did i do wrong
just installed heat shields on the thunderheader now I have vibration on the right floor board--what did I do wrong--the bolts that hold the floorboard are not squeezing the bracket but they are secure
thanks
Old Nov 22, 2008 | 11:42 AM
Bluesssman's Avatar
Bluesssman
Need more info... sounds like a clearance problem when the engine is running...
Old Nov 22, 2008 | 11:45 AM
lkr0's Avatar
lkr0
correct the piece that the floor board attaches to is touching the heatshield--I don't see how I can get heatshield closer to the pipe
Old Nov 22, 2008 | 11:46 AM
Bluesssman's Avatar
Bluesssman
That is your vibration! Can you gently bend the heat shield away from the floor board?
Old Nov 22, 2008 | 11:55 AM
lkr0's Avatar
lkr0
thank you -- going 2 do some bending now
Old Nov 22, 2008 | 11:58 AM
Bluesssman's Avatar
Bluesssman
Check to make sure the heat shields are installed correctly before bending. Good luck...
Old Nov 22, 2008 | 12:10 PM
Ultra 08's Avatar
Ultra 08
Take off the floorboard and use thick washers between the frame and floorboard mount to move it out away from the heat shields. Some after-market exhaust systems come with these spacers.
Old Nov 22, 2008 | 12:30 PM
DrPlastic's Avatar
DrPlastic
Instead of bending anything just place a few washers on the bolts holding the floorboard mounts to the frame. That should give you a bit more clearance with out being overly obvious.
Old Nov 22, 2008 | 01:50 PM
Zimbob's Avatar
Zimbob
Time for some floorboard spacers, like say 3/4" to 1".
Keithhu
Oct 27, 2013 05:42 PM
audettd
Jul 22, 2011 06:58 AM
Picquet1
Jun 17, 2011 03:25 PM
jcanrun
Mar 13, 2011 08:22 PM
Lucky1958
Jul 23, 2010 10:03 AM
