Why a Piece of Wood under Jiffy Stand?
Old Jan 12, 2009 | 12:25 PM
  #31
Candy Red's Avatar
Candy Red
Originally Posted by ripper43
BS that is an old wives' tale... makes no difference what so ever. Concrete does Not conduct electricity and has No grounding potential.
Not true, you take your battery out and leave it on the concrete floor, and it will go dead.
It is a grounding force, not a conductor
mud flap under the jiffy stand works better than wood, less chance to fall over.
  #32
07FLHRCMarinePatriot's Avatar
I put my bike on the block for the photo below. After the pic I removed the wood and low and behold it wouldn't start! Dang concrete! I'm gonna re-pave with asphalt now!
Attached Thumbnails Why a Piece of Wood under Jiffy Stand?-apes-029-small.jpg
Old Jan 12, 2009 | 12:38 PM
  #33
JonnyD's Avatar
JonnyD
The truth is revealed
With Technical Services Manager Gale Kimbrough
Storing Batteries on Concrete?
Well, here we are within months of the new Millennium, and I’m writing an article about an age old question ..."Will a battery be damaged or mysteriously discharged by allowing it to sit on concrete?" At least once a month, someone calls and asks this question or asks for clarification on the subject
Fact or Fiction
Well, is it true? Will a battery be damaged or discharged by letting it sit on concrete? NO!
Why then do so many people believe that concrete is a battery enemy? Years ago, batteries could have been electrically discharged by sitting on a concrete floor. My dad, for instance, owned an automotive shop for many years. In fact, I grew up on a creeper. My dad reminded me time after time, "Set that battery on wood! I know batteries discharge on concrete because I’ve witnessed it!" And he was right at that time.
Historical Basis
You see, the myth that concrete drains batteries does have some historical basis. Many, many years ago, wooden battery cases encased a glass jar with the battery inside. Any moisture on the floor could cause the wood to swell and possibly fracture the glass, causing it to leak. Later came the introduction of the hard rubber cases, which were somewhat porous and had a high-carbon content. An electrical current could be conducted through this container if the moist concrete floor permitted the current to find an electrical ground. The wise advice of the old days to "keep batteries off concrete" has been passed down to us today, but it no longer applies because of the advanced technology of today’s batteries.
Today’s Technology
For more than a decade, automotive and commercial battery containers have been made of polypropylene, which is a highly insulative material. In fact, the Interstate Batteries poly material is at least five times more insulative than the old hard rubber. Also, tremendous technological improvements have been made in the seals around the posts and the vent systems, which have virtually eliminated electrolyte seepage and migration.
Battery Discharging
The fact is, all batteries self- discharge whether they’re sitting on the shelf or on concrete. This is why we regularly rotate your inventory. As the temperature increases, a battery’s self-discharge level also increases. Some lead acid batteries discharge 4% - 8% per month at a temperature of 80°F. The level of self-discharge is also contingent upon the type of lead plate alloy plus the age and cleanliness of the battery.
If the battery has a surface layer of acid or grime, which is electrically conductive, it self-discharges more rapidly. This surface layer may actually allow you to measure the DC voltage across the battery’s poly case (using a 10 meg-ohm digital voltmeter). For that reason, we recommend that you always keep batteries clean, whether they’re in storage or in a vehicle.
Grandfather Clause
You may now be thinking that you know more than your grandfather, who tells you that batteries stored on concrete will be damaged. Next time your grandfather says that, I recommend that you just say "Okay" and continue about your business. I’m a grand-father now, and I know that we like to have our way and we like to be right. If my grandson, for instance, tries to tell me that concrete won’t damage a battery, you know what I’ll say? I’ll say if you drop a battery on concrete, it will be damaged.
Old Jan 12, 2009 | 01:14 PM
  #34
Geoff's Avatar
Geoff
....kickstand on the concrete while parked in the garage will draw from the battery.
Best one I've heard in a long time.
Old Jan 12, 2009 | 08:34 PM
  #35
JohnScrip's Avatar
JohnScrip
I'll admit - I keep mine on a small piece of 2x4 in the garage more than not - But not because of the battery... I just personally find that it looks about 8.25% more kick-*** when it's up a few degrees.
But now, I have one of those center stands on the way... So I might retire the 2x4 - Even for fitting the jack underneath the bike.
IronPhil
Feb 27, 2015 03:39 PM
Supamag
Oct 11, 2010 06:04 AM
ssls6
Feb 9, 2009 03:48 PM
Tropical Andy
Dec 22, 2008 10:27 PM
harleybiker
May 9, 2006 12:42 AM
