View Poll Results: PC-V Poll Question
I just did PC-V Plug and Play and rode away
65.22%
I installed the PC-V and hooked up the laptop too
30.43%
I run the PC-V and I still intend to hook it to a laptop
8.70%
Multiple Choice Poll. Voters: 23. You may not vote on this poll
Dynojet PC-V Poll
Old Feb 15, 2009 | 09:39 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
Originally Posted by Stang951
Here's the proof too!!
Keep in mind also that I am in New Orleans.....AKA 11' below hell. Tech at the dealer said that because of our elevation we dont get really good tunes.....
Iclick, that was the tech that I told you about. I have alot more confidence in him now that I talked to a few of my friends. It seems that all of them trust this guy to work on their bikes when they HAVE to bring it to the dealer.
These are very reasonable numbers considering the your runs were made in 59% humidity YUCK! The AFR curve looks very good which provides a great example on how well the EFI system can compensate for conditions, however you simply cannot replace the air to make high dyno numbers with this humidity.
__________________
Jamie Long / Fuel Moto USA
The USA's Leader V-Twin EFI & Performance www.fuelmotousa.com
Contact 920-423-3309
Email jamie@fuelmotousa.com
Old Feb 15, 2009 | 09:41 PM
Stang951's Avatar
Stang951
Jamie, I sent you an email, glad you found this thread. Wanted you to see the dyno numbers and get your opinion.
Old Feb 15, 2009 | 09:52 PM
fuelmoto's Avatar
fuelmoto
Platinum Sponsor
As far as setting the throttle position settings: On 08-09 drive by wire they are very consistent due to the TPS/Throttle body design and from the 08-09 bikes we have tested most of them are within spec and do not need to be adjusted. It is also important to note that you will only concentrate on the closed throttle position and the bike must be up to operation temp, also unless you have a dyno you cannot reset the open position. If you have incorrectly set or changed these values you can contact us and we will get you the defaults. On the 07 and earlier models (or 09-previous non-touring models) I do recommend checking and/or resetting the throttle position settings especially noting the closed position. I will be writing up complete instruction and putting them on our website in the next couple days for all models on our dynojet tech page here http://fuelmotousa.com/faq.htm If anyone has any questions in the mean time feel free to contact us.
Old Feb 15, 2009 | 10:03 PM
JayStronghawk's Avatar
JayStronghawk
Thanks for Chiming in Jamie defitely be getting hold of you next time want to do an upgrade for now the PCIII is working fine on my 08 EGS but wish had been steered your way before did the Stage 1 and PCIII by the seat of my pants..
Old Feb 15, 2009 | 10:56 PM
iclick's Avatar
iclick
Interesting. Would humidity alone make a difference of 7-10 ft. lbs. of TQ? I thought the dynos compensated for humidity and temperature. No? Anyway are you saying that high humidity decreases power? I thought it was the other way around.
I also thought the difference might be the fact that the bike only had 1k on the clock. Wouldn't a reasonable break-in like 10k miles raise these numbers considerably?
Old Feb 15, 2009 | 11:26 PM
JayStronghawk
Here was Run out after tuned the Red is XIED's Stage 1 The Blue is after the PCIII is tuned in .. Stage One is Ness Big Sucker and Python Slip Ons...
http://s578.photobucket.com/albums/s...rtsNewDyno.jpg
RPS1981
Apr 1, 2012 06:58 AM
Canuckle
Jun 8, 2011 02:19 PM
Cheiron
Aug 20, 2010 11:05 AM
NAUIdvr1
Sep 28, 2009 07:47 PM
Kielbaso
Apr 23, 2009 02:28 PM
