Question on Drivers Backrest
Old Mar 28, 2009 | 07:35 PM
tslonige's Avatar
tslonige
I also used washers under the front bolts.
Old Mar 28, 2009 | 08:15 PM
Neckball's Avatar
Neckball
Bought the HD drivers backrest last summer, and rode with it all summer. I like it pretty well, but it has always seemed like it was standing too straight up-almost leaning forward and pushing me forward. I've been considering taking it loose (its the quick detatch backrest where you squeeze together to pull it out) and putting it in a press and (gently) bending it backwards just a tad right where it goes through the seat.
I managed to make mine work without bending. I added a couple of washers under the mount where it attaches to the fender, & took the strap that bolts to the frame & made a new one.
I had the adjustable one and had to do the same thing.
yep there is a set screw to adjust the angle. Its screwed as far out as it will go--still leans too far forward.
I'll try the washer thing before I do any bending.
i put mine in the vise removed the spring so that I could get a pipe over the two pieces at the same time and bent them until I was happy with the fit.
Absolutely unbelievable that the MOCO can't get this right. None of this is necessary with a Mustang backrest. 2 minute install and a simple thumbscrew for adjustment which can be done while your riding.
Old Mar 28, 2009 | 08:16 PM
stro1965's Avatar
stro1965
I bent mine. It was pushing me way to far forward. I found the bars REALLY hard and had to heat them to bend them. It's been perfect ever since. I managed to get it right in the middle of the set screw adjustment range.
Old Mar 28, 2009 | 09:33 PM
RKCjum03's Avatar
RKCjum03
I had the same problem with mine. I was being pushed to forward. I did what you said in your first post. Put it in a press and bent it. Bending it back a little helped out a lot. If you need to adjust , you still have your screw to adjust with. I tryed the washers to slant it back but it did not work. I put it in a press and used a 1" or so pipe between the backrest bars and press to bend it. Used the pipe so I would get a round bend on the two bars. Worked out good. Use it on a 09 ultra.
Old Mar 28, 2009 | 09:59 PM
qwest's Avatar
qwest
A couple of washers under the front mount did the trick for me.
Old Mar 28, 2009 | 10:53 PM
bosco 09's Avatar
bosco 09
i took a die grinder and notched the rear of the mounting bracket [2@] where the backrest bars rest against. be careful as a 1/16" notch translates to much more at the top of the backrest. worked great for me your results may vary.
Old Mar 29, 2009 | 11:10 PM
ezryder62881's Avatar
ezryder62881
Thanks for all the input guys. I'll try the washer thing first and if that doesn't do it I'll bend it with a press. Just kinda happy to know I'm not alone in thinking that the angle is too far forward. Don't understand why they don't allow more adjustment. Seems a simple thing to do when they engineer the damn thing.
Old Mar 29, 2009 | 11:23 PM
dhincc's Avatar
dhincc
My adjustable backrest pushed me forward when it was adjusted where I wanted it. Stuck it in a vice and bent it where it works for me.
hallfleming
Jul 19, 2014 10:51 AM
rob0225
May 9, 2013 09:44 AM
SecurityGeek
Mar 11, 2011 08:39 AM
PTAG
Sep 15, 2009 09:04 PM
HarlyFan
Oct 26, 2007 09:16 PM
