I have an electra glide ultra classics 2007 and have installed just recent a kuryakin indicator set and rear run turn brake controller
I can not make it work properly lik ethe indicator lights will not stay on and blink orange when taking a turn
i have the right amount of load equalizers installed
can this be because i have installed in my top covers a additonal brake light which still has bulbs
please adviser
Easiest way to tell is to unplug the bulbs in the top covers to see how it works. I believe this is causing your problem. You need to wire them in on the "Trailer" wiring side of the lighting kit. Not knowing which mode lights makes it hard to tell exactly.
