Re-applying weather strip on inner fairing
Old Apr 26, 2009 | 08:59 PM
SecondChance!!'s Avatar
SecondChance!!
Default Re-applying weather strip on inner fairing
I took off my inner this past week and painted it. I am now going to put it back together in the next few days. I am needing to know if I should use the old strips or get new ones? That and if I use the old ones, what should I use to reattach them. They are not tore up. Thanks.
Old Apr 26, 2009 | 09:04 PM
HOGNIT's Avatar
HOGNIT
Get new ones, for what they cost it's worth it. If i remember right they were like 10 or 15 dollars. New ones come with sticky stuff in them.
Old Apr 26, 2009 | 09:45 PM
Beemervet's Avatar
Beemervet
Using a toothpick, lay Super Glue into the strip, and reinstall it onto the inner. Even new, that strip does not hold well, especially after getting dislodged once.
Mine hasn't budged for over eight years.
Old Apr 26, 2009 | 11:18 PM
Harleypingman's Avatar
Harleypingman
A few dabs of RTV clear silicone will work fine.
I just bought new ones for reinstalling my newly painted fairing. With a new paint job, I didn't choose to use the old gaskets; they do age, at least on my '04 EG.
Old Apr 27, 2009 | 12:55 AM
2003flhtci's Avatar
2003flhtci
I reused mine...mounted them with 3M automotive double stick tape...the red-backed stuff. Easy and clean. And that tape defines agressive adhesive...
Old Apr 27, 2009 | 02:05 AM
emwolb's Avatar
emwolb
if you've ever used the yellow gorilla snot glue, it's very sticky, a rubber cement sort of stuff in a tube, by 3-M, they also make it in black and available at auto zone or most parts houses. i use the stuff a lot, it works great for attatching stuff that you want to stay put. crazy glue would likely dry before you could get the part back in place. and the double stick tape should also work, i just mentioned the gorilla snot cause it's what i keep in stock here at my shop.
Old Apr 27, 2009 | 07:51 AM
1flhtk4me's Avatar
1flhtk4me
If the old fairing trim is in good shape you can reuse them.
It's a good idea to scrape out all of the old adhesive first.
I used Loctite Super Glue when I re attached the trim on mine.
I had already taken mine in the shop 2 or 3 times for the dealer to fix this issue.What ever adhesive they used would turn to goo in the heat and the trim would come off in a few places.
Mine have not come off since using super glue
Old Apr 27, 2009 | 08:01 AM
n8dc's Avatar
n8dc
3m weather strip adhesive.. They make it in black too
BelchFire
Mar 28, 2024 11:11 PM
rkoivisto
Detailing
Oct 20, 2016 07:18 AM
djwlbk
Jun 29, 2013 11:15 AM
VWHX
Jan 16, 2012 11:20 PM
lenny
Jan 4, 2007 11:50 PM
