Auto Tune Installed
Old May 20, 2009 | 11:20 AM
nemick's Avatar
nemick
Thumbs up Auto Tune Installed
I already have the Fuel Moto Power Package comprising the Jackpot mufflers, SE A/C and PCV. I have been very pleased with this set-up from the day I installed it.
Yesterday, I installed the Auto Tune modules to complete the system. I was not expecting anything too dramatic for an improvement, as the pre-loaded map is pretty close. However, I felt an immediate difference in smoothness and throttle response. The engine pulls more smoothly through the revs and just generally seems happier and punchier. Heck, it even sounds better.
One oddity that I have not seen mentioned elsewhere is the fact that the tach will not read above 5120rpm. I thought I was having a problem, but Jamie at Fuel Moto was quick to help allay my fears. Apparently, the engine is revving above 512o rpm, but the tach is controlled by the stock ECU. So, If you have this system, be aware that even with 'rev-extend' enabled, the tachometer will go no higher than 5120 rpm, even though the engine will.
All in all, I am delighted with this system, the service and support I have received from Fuel Moto.
Old May 20, 2009 | 11:26 AM
Twinrider's Avatar
Twinrider
Sounds great. Was it just plug and play or did you have to input any settings?
Old May 20, 2009 | 11:39 AM
JustDennis's Avatar
JustDennis
Pretty much the same as my experience. I really like the AT and it seems like the longer I ride with it the better it gets. I have saved the trims several times and my stored map seems to be getting very close. Pretty soon I plan to add a switch so I can switch AT on and off. That way I can store my base map and then set AT up to run with leaner AFRs for a little better fuel mileage. WHen I run in hotter weather, I can then switch AT off and be running on the richer stored base map.
Old May 20, 2009 | 11:42 AM
nemick's Avatar
nemick
Definitely plug and play, at least mine was, when bought from Fuel Moto. I took the time to route everything nicely. Initially I thought I would have to input AFR targets for the Auto Tune, but they were already there. This is a really powerful and fantastic system.
Old May 20, 2009 | 11:50 AM
VTwin-Goodies's Avatar
VTwin-Goodies
Former Sponsor
Sounds like another good add on form another quality sponsor here. Too bad my bikes is a 2002. No auto tune for me.
Old May 20, 2009 | 12:35 PM
Lowridin packer's Avatar
Lowridin packer
What kind of mileage are you getting?
fripple's Avatar
fripple
How much is the auto module add on?
Old May 20, 2009 | 01:25 PM
nemick's Avatar
nemick
I haven't done enough running to be sure yet. Before adding Auto Tune I was getting about 40.
Old May 20, 2009 | 01:26 PM
nemick's Avatar
nemick
I paid $311.00 including Priority Mail.
Old May 20, 2009 | 03:47 PM
iclick's Avatar
iclick
I don't know why not. You have Delphi like I do, and if the PCV works you'd only need to add bungs for the O2 sensors and plug it all together.
