Cam Upgrade on TC96
Old Jun 30, 2009 | 02:01 PM
edgerider's Avatar
edgerider
Default Cam Upgrade on TC96
I want to replace my stock cams in my 2007 RKC with a mid-range cam. I'm looking at the Andrews TW-26H - I do a lot of solo riding, but also 2 up about 30% of the time on country road rides and longer tours. On the highway, cruising is usually 70-80mph, in 6th gear that's just pushing up to 3000rpm. I can't imagine needing high end torque as I don't ride that fast, who can afford the ticlets I see lots of comments on using the Andrews 26, also the 37 and 54H. I do not want to do anything except have the cams bolted in, remap my Thundermax Autotune, and go - no other engine work or expense, poor man's upgrade. And, I'm leaning heavily towards Andrews product.
Any help in making a definitive choice would be greatly appreciated. Thanks!
Also, just getting a blog up and running - infant stages.
http://www.harleyculture.com
Old Jun 30, 2009 | 02:17 PM
stro1965's Avatar
stro1965
I think you'd be very happy with the 26H cams, I know I am. Matrix and I were both having some cold idle issues and recently switched base maps to 525. Seems to have done the trick, running great!
Old Jun 30, 2009 | 02:21 PM
iclick's Avatar
iclick
It's a trick finding a cam set that will retain low-end torque without increasing CR, if that's important to you. The HD SE255's will give an impressive performance boost from 2000-5000 RPM's, especially 2500-4500, without losing anything in the low-end. Peak HP is not greatly increased, perhaps 5%, but if you aren't at the redline often it doesn't matter. I did a write-up on the install and impressions here.
Old Jun 30, 2009 | 02:40 PM
HD Renegade's Avatar
HD Renegade
My tuner is saying to go with the Andrews 50. Says that the 26 is not enough for the weight of the Touring class Harley. I went with the HQ - 0034 and I am not very happy with the outcome of it.
Old Jun 30, 2009 | 03:01 PM
iclick's Avatar
iclick
I don't know what your tuner means by "not enough," but looking at the specs on the 50H suggests to me that it is less suitable in a touring bike than the 26H or 21H. With its 48° intake close it will certainly provide less low-end than the 26H.
What most want and need in a heavy touring rig with tall gearing is low-end and midrange torque, and most aftermarket cams will hurt the low-end while increasing midrange and top-end performance, that is unless CR is increased.
If you want a boost without losing the low-end and retaining the stock CR you are very limited in your choices, IMO. As I mentioned before I believe the SE255's are the best cams on the market for this application where 2000-4500 RPM is the most important operating range in an otherwise stock TC96 engine with a tuner, free-flowing AC, and slip-ons.
Old Jun 30, 2009 | 05:04 PM
HD Renegade
I Agree with the rpm numbers you say here, and I am no expert at all. I come here to read, ask, and listen to what others have done and found. My tuner has been building and working on Harley for 20 years. I can only give the numbers I have from the dyno. I will be posting a review of things soon once I get my ducks in a row. I have spent a lot of cash in the last 4 months on trying to gain more power. I have changed cams, air cleaners, and pipes. The duals vrs 2-into-1 is a BS myth as far as I am concerned.
The biggest power gain I have seen is from an air cleaner change, from HD stage 1 to a SPP w/crank vents. I think the gain was 12 hp with Dyno to prove it.
Please keep in mind, I am not trying to argue with anyone here, I am just sharing what I have done and what I have seen from it.
Old Jun 30, 2009 | 05:25 PM
badjustbad's Avatar
badjustbad
Same with me - not trying to argue, but I agree with you 100% the 2-into-1 claims are pure myth. I also feel the cost of a "Stage I" upgrade is pricey for what you get (And I got good TQ/HP numbers when I did it.). The biggest bang for the buck in my experience was the cam install. Of course you need all the supporting goodies (intake, mufflers, EFI tuner, etc.) but the cam is the missing piece that gives you the bang for the buck you are looking for and the cams were the cheapest part next to the new pushrods (I did my own install.).
Old Jun 30, 2009 | 08:11 PM
jag1886's Avatar
jag1886
I used a HQ500 cam with a Big Sucker 2 and a FatCat with quiet baffle in my 07 96" RC and it made 90HP and 93 Torq.
It is in the shop right now because the dyno guy got it a little lean on the bottom end which was screwing up the drivability in town but man it ripes on the highway.
Old Jun 30, 2009 | 08:51 PM
SE120RG's Avatar
SE120RG
I have to agree that the 255's are a great cam for the 96 if you are looking for low-mid range grunt. I followed Iclicks advice and got a used set. I spent $400 on cams, bearing puller/installer, cam install kit, adjustable pushrods and SE HP clutch spring. I also spent some coin on a dyno tune to complete the set up. The maps from fuel moto just were not working for me. To me this has been the best bang for my buck.
Old Jun 30, 2009 | 09:31 PM
iclick's Avatar
iclick
How much increase in lever pressure did you feel after installing the HP clutch spring? I wonder if it is needed if only cams are changed, along with the usual Stage 1 mods, of course.
