Need help installing: Headlight visor trim ring
Old Dec 7, 2009 | 05:40 PM
Coastiejosh's Avatar
Coastiejosh
Default Need help installing: Headlight visor trim ring
I've read the directions and installed, and there is about 1/8 inch gap all the way around the headlight on the inside. There is nothing in the directions that say what to do. Is there a spacer that people are using or making to solve this issue? Anyone have idea what to do to fix this problem?
Part # 69733-05
2010 Street Glide
Thanks for the help!
Directions below, minus the picture.
-J01369 REV. 2005-09-12
7 INCH HEADLAMP TRIM RING
GENERAL
Kit Number
69627-99 and 69733-05
Models
These kits fit 1983 and later Touring motorcycles (except Tour
Glide and Road Glide). Kits also fit 1994 and later FLHR
models, and 1986 and later FLST models with accessory
Chrome Headlight Nacelle (Part Number 67907-96).
Kit Contents
See Table 1 and Figure 1.
Table 1. Kit Contents
Item Description Part Number
1 Screw 3824
2 Nut 8006
3 Trim ring Not Sold Separately
INSTALLATION
1. Loosen original equipment trim ring screw.
NOTE
If the original equipment trim ring screw is not loosened, the
accessory trim ring will not fit properly.
2. Slip new trim ring over original equipment trim ring. The
lip on the back of the accessory ring should slip between
headlamp housing and original equipment trim ring.
NOTE
See Figure 1. Screw and nut may need to be removed to allow
trim ring to slip over original equipment trim ring. Position
mounting screw of accessory trim ring at bottom of headlamp.
is00864
Figure 1. Headlamp Trim Ring
3. Tighten original equipment ring screw.
4. Tighten accessory trim ring screw.
Old Dec 7, 2009 | 05:42 PM
themensh's Avatar
themensh
I figure it is either:
1. Normal.
OR
2. A Harley thing.
Mine has a slight gap also.
chuck (living with the gap)
Old Dec 7, 2009 | 05:48 PM
tencrore's Avatar
tencrore
Try this thread;
https://www.hdforums.com/forum/touri...g-fitment.html
I used the foam tape method without the original trim ring and it fits like a glove.
Hope this helps.
Old Dec 7, 2009 | 05:52 PM
StreetGlider56's Avatar
StreetGlider56
Just take the screw out of the original ring and it'll close...
Old Dec 7, 2009 | 06:02 PM
Coastiejosh
tried the screw and thats don't the problem. The problem is, its poorly made and its not a true custom fit.
Old Dec 7, 2009 | 06:08 PM
Yachtman's Avatar
Yachtman
Try a beer then a baseball bat, or maybe the bat first and then the beer!
Old Dec 7, 2009 | 06:09 PM
user 8373900's Avatar
user 8373900
The gap you are worried about is a product of headlight adjustment..The headlight wouldn't work very well pointed straight out and level forward. The ring wouldn't look good if it was all cockeyed to meet the light.
You can't see it when riding and no one else cares if there is a gap. If you got the gap at the bottom closed you are better off than most!!
Mark
Old Dec 7, 2009 | 06:17 PM
nocarb's Avatar
nocarb
I just call mine a bug catcher.
Old Dec 7, 2009 | 06:18 PM
gmc's Avatar
gmc
You can put some washers behind the retaining ring that holds the headlight to bring it out. You are probable hitting the fairing, right? Like onedn says you will need need to play with the adjusment to keep the headlight pointing correctly.
Old Dec 7, 2009 | 06:30 PM
Buzzsaw's Avatar
Buzzsaw
I followed the directions, kept the original ring screw loose until it was almost closed, kept loosening the Trim ring screw, squeezing the ring and tightening and squeezing. Took patience and got it all the way closed.
If the gap you are talking about is on the right side in this picture, that is from the headlight aiming and is the adjustment of the Lens. Did not touch those screws.
Attached Thumbnails Need help installing: Headlight visor trim ring-trimringfrontview.jpg
