Monkey Bagger Bars with Pics (Install)
Old Oct 20, 2011 | 12:11 PM
  #261
MILLER41143's Avatar
MILLER41143
i just got my wires pulled thru last night on the 16 inch yaffe bars they were pretty tough i almost gave up but glad i didnt
i will have some pics later hopefully
Old Oct 20, 2011 | 06:29 PM
  #262
MassHD's Avatar
MassHD
You should have them Mr Hog
Old Oct 27, 2011 | 07:54 AM
  #263
InMotionJosh's Avatar
InMotionJosh
My 10" OEM Monkeys will be here Saturday. Id like a copy of the instructions to josh@inmotionbuilders.com please.
Old Oct 27, 2011 | 09:50 AM
  #264
BuckeyeRider's Avatar
BuckeyeRider
I could really use the instructions / tips. tvanover2129@wowway.com
I am in the middle of the project. I got the TBW thru but can't get the pins free from the molex style coupler. Do I need a tool? I tried p clips etc and can't find the magic spot to release them.
Old Oct 31, 2011 | 04:36 PM
  #265
Mr HOG's Avatar
Mr HOG
Got my bagger apes installed last week. I've done a couple of tall bar installs in the past but this was the most challenging by far. The instructions provided here helped but didn't tell the full story. The biggest problem (if you have TBW) is the green plug connection. If i had it to do over i would splice the wires and eliminate the plug. Anyone doing this project wanting further advice shoot me a message.
For the 12 in apes, i went with 8" over clutch and 6" over on the brake cable. I did reroute the brake cable out the same hole as the handlebars. I also orded the TBW extension but didn't need it. Also ordered the switch wire extension kit which saved me a lot of time. Although it may be possible to reroute the factory wiring (and eliminate the extensions) it was easier to just add the extension wires.
Here's a couple of pics. Overall, i'm very happy with the look and comfort of the bars.
Old Nov 18, 2011 | 11:21 AM
  #266
HDBuck's Avatar
HDBuck
Could I please get the instructions. buck.furger@gmail.com
Thanks
Old Nov 21, 2011 | 01:01 PM
  #267
BuckeyeRider
My bike is apart in the garage and I need heed help. I just can't get the switch wires and TBW wires thru the right side of ny 10" yafees.
Anyone have the email or pm that has the tips I would greatly apreaciate it.
Old Nov 21, 2011 | 01:55 PM
  #268
BIGVTWIN's Avatar
BIGVTWIN
Okay bud where you at on these? Did you get the connectors unplugged?
Old Nov 21, 2011 | 04:48 PM
  #269
Mr HOG's Avatar
Mr HOG
I spoke to BR about his issue. The problem with the right side on these TBW bikes is the big green plug connector. With all the switch wires coming through the right side, there is just not a big enough opening in the bend to pull that big *** connector through. Most likely the connector will come loose if you try to pull it through. I shrink wrapped my connector and even tied some string across the connector and it still came loose. The only other option is to get the green plug down as close to the bend as possible and shove the remaining wire into the end along with the TBW assembly (which is what i did) or eliminate the plug. HD sells an SE TBW that eliminates the plug or you can just clip the plug and solder the wires together.
Old Nov 21, 2011 | 05:42 PM
  #270
BuckeyeRider
As Mr Hog stated I have had problems with the green plug but right now I have the tbw wire through. Its not connected to anything yet. This is my 3rd attempt and just cant get the switch wires past the corner with the tbw wires thru. Mt hog said he pulled both sets thru at the same time which I have not tried yet. I've greased them, sprayed them but get stuck and don't want to rip the wires apart.
Will try again Thurs or Fri.
