Monkey Bagger Bars with Pics (Install)
Old Nov 21, 2011 | 05:52 PM
  #271
Mr HOG's Avatar
Mr HOG
Originally Posted by BuckeyeRider
As Mr Hog stated I have had problems with the green plug but right now I have the tbw wire through. Its not connected to anything yet. This is my 3rd attempt and just cant get the switch wires past the corner with the tbw wires thru. Mt hog said he pulled both sets thru at the same time which I have not tried yet. I've greased them, sprayed them but get stuck and don't want to rip the wires apart.
Will try again Thurs or Fri.
Have you got the green plug on the down side of the bend? You might be able to get the switch wires through the bend if the plug is out of the way. I tried doing them at the same time and it just wouldn't happen. More than one way to "skin a cat." Let us know how it turns out.
Old Nov 24, 2011 | 05:42 AM
  #272
Wanna Ride's Avatar
Wanna Ride
Buckeyerider, did you have any more luck at this? I'm running into the exact same problem right now. I just came in from the garage, after spending six hours trying to get the right side done, with no luck. I fished everything through three times, and each time I would get a little further along, but no dice. The last time was the farthest. I got the green connector all the way to the corner, and it seperated and tore the heat shrink. I don't see how it's possible to get that in, and then the switch harness too.
If anyone has any more advice other than the youtube video and the Yaffee tips, I'm all ears.
Does anyone know how much the SE TBW harness costs?
Old Nov 24, 2011 | 06:58 AM
  #273
BuckeyeRider's Avatar
BuckeyeRider
I haven't tried it yet. Will get back out friday. Some tips I got was to cut the sheathing off both harness and tightly wrap both together with elect tape. Also heard to remove the green plug and solder the joints.
If you run both sets together make sure to measure right so they are correct length by the top.
I'll post tomorrow after I try again.Supposed to be 60 and would love to ride.
Old Nov 24, 2011 | 07:30 AM
  #274
sweetglide103's Avatar
sweetglide103
just had my 12" installed by the dealer....they told me they had alot of issues installing them.....but i don't believe a damn thing they tell me either....ive caught them in lie after lie.......but reguardless...their on and i love them....enjoy
Old Nov 24, 2011 | 07:56 AM
  #275
WIKD1's Avatar
WIKD1
When I did mine I found that by twisting a piece of wire, I used a depapered bread twist tie, around the green plug lengthwise so it couldn't pull apart and then covering the plug with tape to smooth it out I was finally able to pull it all through. A little lubricant didn't hurt either. That damn green plug of the TBW took longer than all the other wiring together.
Old Nov 24, 2011 | 09:57 AM
  #276
Mr HOG's Avatar
Mr HOG
SE TBW is around $80 i think. Easiest way is to cut the green plug out and solder the wires together. The plug is only there to make changing the TBW assembly easy. Once you get rid of the green plug the wires should pull through pretty easy. Leave some extra (TBW) wire coiled up inside the bar just below the TBW assembly. This way if it ever goes bad you can pull it out, snip the wires, and install the new one.
Old Nov 24, 2011 | 10:07 AM
  #277
UltraHog's Avatar
UltraHog
If someone has a moment, I'd really appreciate a set of the instructions sent to me as well.
robarber@hotmail.com
thanks
rb
Old Nov 24, 2011 | 10:47 AM
  #278
Wanna Ride's Avatar
Wanna Ride
thanks
rb
rb, check your in-box. I also sent you a link to a helpful video on youtube. When my bars arrived, the same instructions were in the box. But they had been copied in black and white, so the pictures were just about worthless. I'd advise anyone considering tackling this project, that you go through and read this entire thread, as there's several good tips here, that are not in the instructions.
Hope this helps!
Old Nov 24, 2011 | 11:51 AM
  #279
UltraHog's Avatar
UltraHog
Hope this helps!
Got em, thanks
rb
Old Nov 25, 2011 | 12:18 PM
  #280
TexasSG's Avatar
TexasSG
After pulling the connector apart, which broke the retainer, I just super glued it together, didn't come apart after that.
