Monkey Bagger Bars with Pics (Install)
Old Mar 16, 2012 | 07:28 AM
  #451
Nut08Ultra's Avatar
Nut08Ultra
Originally Posted by mike1158
planning to get into mine this weekend... i got my bars, painted inner, poly bushings, SE TBW harness... bike is up on the jack...
QUESTION.... am i gonna be able to reuse my grips? any tips on removal
and re-install?
p.s. i'm doing 10s......i'm only 5'6" i think these should be juuuuuust right.
Whats the SE TBW harness about?
Old Mar 16, 2012 | 07:32 AM
  #452
rg_dave's Avatar
rg_dave
Screaming eagle throttle by wire harness. It relocates the "green plug" to the bottom of the bars. It's normally about 8" into the bar. It makes pulling wires over the sharp bend in MBBs much easier.
Old Mar 16, 2012 | 07:47 AM
  #453
Nut08Ultra's Avatar
Nut08Ultra
Thanks... I figured it had to with length or that thing. But I did know it had something to do with a difference HD does that we don't seem to know why... cuz putting that on all the bikes and not just SE would make things too easy I guess..LOL Oh wait... sure I do.. so we are urged to buy yet another item.
Old Mar 16, 2012 | 12:35 PM
  #454
Dew Me's Avatar
Dew Me
The SE also has wires for heated grips. Now why Harley wouldn't put the green plug at the bottom for both harnesses is the thing I don't understand. Maybe putting it higher means it is easier/less labor time to replace the TBW for the majority of touring bikes? Maybe Harley never thought anyone would want to do internal? Or maybe they really wanted to make things difficult so people would buy the SE TBW? Dunno. You can cut the green plug out and solder back together, thus not giving Harley more money. I just am not enough of a electrician or mechanic to trust soldering my throttle. Something about that just doesn't seem right.
Old Mar 16, 2012 | 01:21 PM
  #455
rg_dave's Avatar
rg_dave
It's pretty easy to pull the wires with the green plug on bars that don't have the radical bend like MBB, carlinis, burly, etc...You can pull it on the MBB, many have done it its just a huge PIA.
Old Mar 16, 2012 | 08:35 PM
  #456
DDEAL's Avatar
DDEAL
I have done quite a few internal wire set ups and have made several wiring extensions. Covered them all with shrink wrap and then coated them with vaseline. Ran a strand of 14 ga. Electric wire through first and attached my harness to it and pulled and pushed it through! Works pretty well but, nothing is completely effortless! Just plan on a few cold ones and take your time!
Old Mar 17, 2012 | 04:59 PM
  #457
mike1158's Avatar
mike1158
in the middle swaping out my inner fairing for painted one and instaling my 10" MBBs
one question...i shouldn't need wire extensions with the 10s, so do i have to remove the wires from all of nthe switches and take that whole thing apart or can i just pull the wires out of the connectors at the other end where they connect under the fairing and pull those ends down through the bars???
anyone have any last minute pointers?
ALSO...and can anyone tell me if my stock clutch and brake line will work with the 10" MBBs?
Old Mar 17, 2012 | 05:07 PM
  #458
rg_dave's Avatar
rg_dave
Leave the wires on your switches and pull from the top to the bottom. You shouldn't need to extend the brake. You may be able to reroute your clutch but I would go with a +2 clutch. I would change to braided lines so I would be changing the brake and the clutch. But I'm an all-in kind of guy.
Old Mar 17, 2012 | 08:16 PM
  #459
JCCASH's Avatar
JCCASH
SG Dave, your bars look great. I have the same windshield as you. Thanks for the picture I'm planning to add bars as well to my SG. Just did a stage 1 upgrade so saving my penny's for the bars.
Old Mar 20, 2012 | 04:22 AM
  #460
2011_Glide's Avatar
2011_Glide
I have read this entire thread and alot of others about this. But, my question is how long does it take from start to finish to get these bars on?
I was told by a mech that it is a 5 1/2 hours job. I think that is a little long..
Any help?
