Cam Project Final Write-Up
1.) static compression
2.) uneven surfaces on the head(s)
3.) too much advance/retard of the timing in the tune itself
4.) too lean
5.) valve clearance
6.) rocker or pushrod adjustments being misaligned
7.) cylinder sleeve shifted
8.) improperly torqued head bolts
the list goes on and on. The questions I have are;
1.) who did the 107" and cam work?
2.) who did the tuning?
3.) have you verified nothing else is damaged? (crank, tappets, pushrods, etc)
4.) do you have a warranty on this build?
I got confused while reading all the pages.
I meant to post here.
Great write up, I am definitely going to do my onw.
I was going to bring it in for tensioners after I change my pipes and a/c then have the cams done too and get it tuned.
Now I think I am going to do this myself and have it tuned after.
Thanks for a great write up.
my questions is about tensioners,
Unless I missed it you didnt do the tensioners while you were in there right?
I was just wondering if you did and I missed it.
I hear a lot of talk about them wearing out and becoming an issue, so I was planning on replacing mine while I do the cams.
I wanted to know if you didn't bother or if I just missed it.
I realize this is an old thread so I dunno if the OP is still around or not.
Lump
Doing the cams is fairly easy. The key is this;
1. Get a service manual, it's a MUST
2. take your time and label everything.
3. take your time
4. take your time
I think you get the point. The first two times I did it, I cut the stock pushrods and put in adjustables. I hated them.. too noisy. So when I did my cams on my 12flhtk a couple of weeks ago, the 254e cams had the same base circle as the stock cams so I pulled the rocker boxes off and kept the stock pushrods. It literally added another 30 minutes to the project.
4.) too lean
5.) valve clearance
I am going to go with my stock pushrods since I only have 1300 miles on the engine since I purchased it in late September. I'm still trying to decide between the SE255's or the TW-222's.
