Cam Project Final Write-Up
Old May 24, 2011 | 11:01 PM
  #121
PHA-Q's Avatar
PHA-Q
Fantastic writeup... With this im on a mission to do the cams in the dyna..
Thanks
Old May 26, 2011 | 10:04 PM
  #122
drspencer's Avatar
drspencer
Just finished putting the SE 255 cams in my 2011 103" Street Glide.
Don't have my TTS tuner yet.
Can I start it up with the original map, just to check my work?
Thanks
Old May 27, 2011 | 06:56 AM
  #123
Eddie Haskell's Avatar
Eddie Haskell
Thanks
I would, as long as your not putting a load on it I don't see the harm
Old May 28, 2011 | 11:55 PM
  #124
drspencer's Avatar
drspencer
O.K., another proud A-Train/Iclick cam-school graduate here.
Followed their directions, and everything went smoothly.
Downloaded the canned TTS map for SE255 cams, and the bike fired right up. No ticking sounds, funny noises, cams shooting out of the side of the engine, etc.
Hardest part of the job? Installing the Fuel Moto head pipe & heat shields.
I can't give enough praise to the two Gentlemen, atrain & iclick, who helped me through every phase of this job. Their patience knew no bounds.
I only wish I had the skills & knowledge to reciprocate the favor.
Thank you, again.
Old May 29, 2011 | 01:31 PM
  #125
iclick's Avatar
iclick
Cool
O.K., another proud ATrain/Icick cam-school graduate here.
Diploma is in the mail.
Voila!
Downloaded the canned TTS map for SE255 cams, and the bike fired right up. No ticking sounds, funny noises....
It's a Harley, so something's definitely wrong here.
I would have to say that futzing with the exhaust and rocker paraphernalia is the worst part of the job. Working in the cam chest is pretty straightforward.
Gentlemen? Who walked in? I guess Atrain must have.
You do. I'll be the first to accept a beer next time I'm in your neck of the woods, wherever that is. I'm always looking for an excuse to start a ride.
Old May 29, 2011 | 08:30 PM
  #126
atrain68's Avatar
atrain68
Thank you, again.
Congratulations on a successful project! Maybe one of these days we can come up with some kind of diploma or secret handshake for the graduates. Then again, a cold beer before, during, and after the project is probably good enough!
Old Jun 9, 2011 | 08:08 PM
  #127
Northern B's Avatar
Northern B
Another A-Train/Iclick grad today as well .... probably wouldn't have tackled it without the inspiration from your write ups .... I have done tons of wrenching on snowmobiles but have never touched a 4 stroke engine before ... I printed all your write ups and had them in a binder as reference as I went along .... awesome, thanks guys!
Just finished installing wood tw-555 cams and RB Racing LSR 2-1 in black ceramic. The bike fired right up and oil pressure light went out right away .... huge smiles! Still got a few things to finish up .... install new base map from FuelMoto and my Autotune, a couple of heat sheilds on the exhaust and Jerzees customs oil pressure guage then good to go.
Thanks again!
B
Old Jun 11, 2011 | 12:50 PM
  #128
ride1's Avatar
ride1
5th Gear
Default cam alignment question
This is a great write-up as many have said. I have been into this project and have questions about cam alignment, timing marks, and cam sprocket positions. I've installed the cams into the cam baseplate and made sure the timing marks line up using a straight edge. After installing the cam plate assembly into the crankcase I prepare to install the cam sprockets following the H-D manual process for aligning the sprockets in the chain. When I apply the two sprockets/chain assembly onto the ends of the cam and crank they don't just slide on. There is a very slight misalignment. The H-D manual says to "rotate the rear cam sprocket in a clockwise direction until the timing mark on the root is aligned with the timing mark on the crank sprocket tooth." How much do you move the rear cam sprocket to get this alignment? 2 degrees, 358 degrees? Doesn't this take the cams out of alignment now? Also, it seems to be the opposite direction I need to go to in order to get the sprocket/chain assembly to slide into place because I can see that if I nudge the rear wheel very very slightly I can get the crank sprocket to 'square' up and get the alignment without moving the cam sprocket. Will this f**k up the timing? Or will this still be okay? I notice in a picture for this procedure in the Day Three write up that the crank sprocket dot is not exactly lined up with the line on the base plate or the cam sprocket. It's very close but not spot on. The H-D manual says "Misaligned sprockets will make the engine run erratically." How erratic? Will it run but have too high compression in one cylinder? Will it run rich in one cylinder and be difficult to tune? Any help here would be much appreciated. I'd hate to have to undo everything (exhaust system, pushrods, etc) again and have to come back to this alignment issue with no confidence. Thanks in advance for any help!
Old Jun 11, 2011 | 03:14 PM
  #129
atrain68's Avatar
atrain68
It sounds like your crank is not quite lined up where it needs to be. Remove rear cam and crank sprockets with the chain. You will see the crank has a flat side. This flat side should be exactly perpendicular to the line that goes between the crank and the rear cam. Rotate your rear wheel very slightly until the crank flat is perpendicular with the line. Now check the cam dots are in the correct position and then reinstall the rear cam and crank sprockets with chain. Everything should line up. If it doesn't align, then send some pictures and let's figure out what happened.
The reason you remove the rear cam and crank sprockets and chain is so the rear cam pulley will not rotate the cams out of position when you rotate the crank to its correct position. If I understand you correctly, this is not a major problem.
Old Jun 12, 2011 | 09:49 PM
  #130
ride1's Avatar
ride1
5th Gear
Thumbs up You're right!
There was a misalignment of the front cam..........by one tooth. I took the sprockets off and looked at the line up as it was showing on the outboard face of the cam plate and recognized that per your advice. Had to remove the cam plate and reset the front cam. Made sure the dots on the face of the cams lined up. I noted that on the outboard side, the rear cam "flat" would line up (center) with the projection of the cast-in diagonal line on the front of the cam plate and the dots of the front and rear cams were in a straight-across alignment. After the cam plate assembly was reinstalled I double-checked the crank flat alignment and then I was able to just slide the two sprockets right into place. The sprocket alignment dots are in the correct position along that same cast-in diagonal line. As an aside: I do have the rear cylinder at TDC. Thanks for the help. Now, could you come over and adjust my pushrods for me? They sure take a lot of wrench twisting! Just kidding. Should be good to go. Raining for the next three days so plenty of time to wrap it up.
