Radio\CD player for FLHT
3 screws to remove the windshield, 4 screws to remove the outer front (painted) fairing. As you pull off the fairing, disconnect the plug that goes into the headlight.
Now pull the two screw on either side of the radio spacer that is in your bike now...(total of four)
Soap up the front edges of your new radio, slide it in.
Plug the preexisting wire bundle into the radio (there is only one that fits).
You're done.
Before you go any further, you need to get after market speakers as the ones that come with the radio aren't worth the crap it took to make them. www.hogtunes.com will get you a set for right at $100.
You will also need an antenna. I highly recommend the powered antenna from Dakata Digital...
http://www.dakotadigital.com/product...ategory118.htm
Will get you there, you want the ANT2000.
Plug that in, put in the speakers. (3 screws each, and slide the connectors on both).
Put it back together (3 screws for windshield, 4 for the fairing)...
Ride and SMILE.
Let me know if you have any problems, or if you need pics of anything inside. I will take it all apart and get some if you need.
Mac
www.mandmcycles.com
The hyperlink picked up the period and threw things out of whack.
Russ
Post pics when you're all done!
Mac
