Oil Use?
Old Jul 18, 2006 | 10:17 PM
redhwk44's Avatar
redhwk44
Default Oil Use?
Hi everyone,
As I am new to the forum I know this has been covered but I gotta know. I just bought an '06 RKC and am due for the 1000 mile oil change. I have put about 1200 miles on it and it is a full qt low. I am on my first Harley but have had several rice burners and none of them used any oil. My question "is this normal?" I spoke with the stealer about it on the phone and he said Harley says it is "exceptable".Any and all info would be appreciated
Old Jul 18, 2006 | 10:25 PM
MACK's Avatar
MACK
Default RE: Oil Use?
that is a little heavy but not out of the norm. you should use very little now after break in. use amsoil and you wont use any. i just got back from a 5000 mile journey oiut west to montana where i constantly hammered the bike for 85mph almost everyday and almost all day long. didnt use a drop. i have a 95inch big bore with andrews gear drive cams hi po exhaust and race tuner. 33000 miles on the bike.
Old Jul 18, 2006 | 10:26 PM
dawg's Avatar
dawg
What type of driving you been doing? If you run 80 mph on the interstate often, it can get a quart low. I had my ride go a quart low after several long interstate trips.
Old Jul 18, 2006 | 10:32 PM
redhwk44's Avatar
redhwk44
Well, I broke it in like the service manager said {at least for the first 50 miles } then I rode like I would any bike. Most of my riding lately has been pretty light, no hard excellerations, and nothing over 70mph sustained.
Old Jul 18, 2006 | 10:35 PM
redhwk44's Avatar
redhwk44
Hey Mack
Is Amsol an oil additive? Where do I find it. What is everyones thoughts on the synthetic oil. I have heard that if you want to find any leaks to use synthetic. Will I burn more oil if I use the synthetic?
Old Jul 18, 2006 | 11:02 PM
bountyhunter's Avatar
bountyhunter
After initial break-in, you should use virtually NO oil. I don't use SYN.
Old Jul 18, 2006 | 11:05 PM
soos's Avatar
soos
85 MPH? Didja see anything?
Old Jul 18, 2006 | 11:20 PM
EDCT100's Avatar
EDCT100
Just had mine in for the 1k check....down about 1/2 qt. Told this was normal at first. I did hear to switch to syn at the 2nd maintenance check-up. Plan on doing that. Good luck.
Old Jul 19, 2006 | 03:09 AM
oldfartjc's Avatar
oldfartjc
ORIGINAL: redhwk44
Hi everyone,
I have 1600 miles on mine and it has not used any that I could see, maybe a little during the first 1000, hard to say, but it's been right on since my 1K sevice. I use 20W/50 regular Harley oil in the engine.
Old Jul 19, 2006 | 08:28 AM
bdgreen's Avatar
bdgreen
I kept mine at or below 3000 RPM through first 500 miles per dealer instructions and then changed fluids at 1100 miles. Had not used any oil through first 1000. I switched to AMSOIL Syn. when I changed the fluids and it seems to be running a little quieter and smoother. Also used RevTech per local Indy for tranny and primary. I DEFINITLY got a smoother shift and it drops into nuetral way easier.
