Project 124
Old Feb 4, 2010 | 08:52 PM
  #71
PhilM's Avatar
PhilM
Well…. I couldn't stand not doing anything! Who'da thought…???….
Here's some new hardware. Stainless intake & exhaust bolts. studs, nuts….
First thing on schedule today was CLEANING…. serious cleaning! Most things get lacquer thinner cleansing, followed by HOT soapy cleaning in Momma's kitchen sink. After things are clean & dry, they get bagged & grouped for install.
Now for some final assembly…. Rear piston on the rod, w/wristpin & clip. These longer stroke motors have the wrist pin slightly passing thru the bottom ring groove, so the piston has to go on the rod before any of the rings. Also before the bottom rings go in, is a "platform" ring that fills the gap where the wrist pin goes...
Double & triple check ring placement and be sure they are "right side up". If they have a dot, it always goes up. Here's the middle ring ~ dot up.
There's the top ring. It does not have a dot, but the inside edge has an angle cut. On a "top ring", the angle cut always faces UP. Look closely at the edge of the ring, just past the stud. on the top, inside edge, you can make out the angle cut. The cut allows air (pressure) to get behind the ring as it travels up, and forces the ring out against the cylinder wall. The opposite is true for the middle ring: the angle faces DOWN and as the pistons descends, the pressure causes it to firmly press against the cylinder walls. Make sense?
With the rear piston, cylinder, & heads installed and properly torqued, its time to move to the front. Here's one of the things that needs to be checked, particularly on the long stroke, big bore motors. There is a point, during each revolution, when the rear piston is all the way down, that the rear skirt of the front piston actually passes into the space (typically) occupied by the rear piston. Here, you can just barely see the bottom edge of the rear piston behind the curved relief in the rear cylinder spigot. S&S did an excellent job with these and clearance is A-OK. Probably goes without saying because they've been doing big motors for a LONG time, but still needs to be checked out, nonetheless.
These bigger pistons don't leave much room for working with the rings, with hose over the studs to protect the pistons. Tried something different on the front & it worked well. Hose on the load bearing studs & tape on the other two…
….and finally, both heads are in place and ready for rocker boxes, rocker, intake, etc….
More after I get back from the trade show.....
Old Feb 4, 2010 | 09:01 PM
  #72
JUICE1's Avatar
JUICE1
very nice. whats the website for the tman parts?
Old Feb 4, 2010 | 09:05 PM
  #73
BadPiggy's Avatar
BadPiggy
Phil,
Don't be such a tightwad!
Load that badboy up with ALL 12pt. hardware while you have it out!
Old Feb 4, 2010 | 09:06 PM
  #74
hog-doc's Avatar
hog-doc
Looks good Phil. Nice exhuast studs!
Your back must be in much better shape than mine. I will NEVER again build a motor OUTSIDE the frame. Put the bottom end together, stab it in the frame then build the top. Much easier on the back!!!
Old Feb 4, 2010 | 10:31 PM
  #75
PhilM's Avatar
PhilM
http://tmanperformance.com/index.html You probably won't catch anyone there until the middle of next week. I believe they are enroute to the V-Twin Expo in Cinci that runs Saturday ~ Monday.
Originally Posted by BadPiggy
Phil,
I'm open for charity support!!!
Actually, I have a chiropractor on first name basis.... : ()
I did my 120 this way too & man is it ever easier to work on this way. I've some some gorilla strong buds that I'll enlist when the time come.
Originally Posted by Mark MPDC
So what is better to get if a person was to get a 124 build done this way which phil is doing or buying a s/s,revtech,tman motors already built so you just basicly swap out your motor and put in the 124.
There's merit and a "fit" for either strategy. Personally, I just dig working on them and "in the end" you can do some extra stuff when ya "build" vs. buy.
Whichever works & is "right" the the one foot'n the bill & twist'n the grip is the way to go.
Old Feb 4, 2010 | 10:44 PM
  #76
Dalton's Avatar
Dalton
Well, first off, a complete motor is going to cost you way more than if you build it yourself, all things being equal. Second, if you have the skills, you know when you are done it is exactly right. You can see that Phil is meticulous about cleanliness and double checking measurements/clearances and all other items. Yes, you can buy some big inch crate motors, but are they exacting in assembly such as this will be. I have done many builds including my big inch build, and would recommend that if you have the skills, tools and patience, to do it yourself as long as you have someone on speed dial to help you through it.
Old Feb 5, 2010 | 01:33 AM
  #77
kingkingking's Avatar
kingkingking
For 06 and later the only crate motor is a Jims. S&S dont make them as HD sued them.
For your 04 I would go with a crate S&S, I like their cases better.
Old Feb 5, 2010 | 01:18 PM
  #78
PhilM's Avatar
PhilM
Originally Posted by buttman
Have you decided exactly what exhaust you will be going with?
Initially, I'm gonna go with a Boarzilla headpipe with a SuperTrapp tuneable can. Kinda like what I first tried on the 120. I didn't like the Zilla on the 120, so I want back to the FC w/perf baffle. This one's gonna breath a bit more though. Here's what it looked like ~ the first time I made one...
For the hanger, I just took one of the pipe hangers (form under the saddlebag) and welded it (upside down) to the can and used some threaded couplers for the mounting bolts... Worked well. Knew I never should'a sold that F'r!
If this doesn't satisfy me, I also have a new SuperMeg.
If neither of them work out, I am on the contact list for when the "Guppy 4" hits the street.
Old Feb 5, 2010 | 07:48 PM
  #79
mudbone13's Avatar
mudbone13
Wish I could be there in person and learn all this great engine building. Pictures are great, but to be there in person would be so awesome. Appreciate all the pictures and explanation. I wish that there was a class to learn how to do this!!!!
Old Feb 7, 2010 | 01:45 AM
  #80
CDP1911's Avatar
CDP1911
Originally Posted by kingkingking
Rebuttal:
"Chrome wont get you home."
"Anyone can do pretty, fast is the domain of the skilled."
BTW its spelled "grammar"...
I'm of the idea a scoot ought to be Real Pretty and Damn Quick; not either or
Mine is pretty dang fast (not as fast as yours but it holds its own)- Phil will vouch. Phil built my motor. As far as being Damn quick; it's just a matter of time. I'll be in a 124 or greater soon enough. Phil has been on me for a month to get er done. And, after talking to TR last week I am hooked.
I agree Chrome wont get ya home. But, it damn sure looks good on the side of the road if its busted. BTW a PhilM built motor is pretty damn reliable too - never a problem.
Now back to our regular scheduled program
and I guess I should apologize now for the spelling - naaaaaa
