aux input port problems!! need help bad!!
Old Feb 22, 2010 | 10:35 PM
Potato_Potato's Avatar
Potato_Potato
No port in the back - although there is a mod to do it.
Old Feb 22, 2010 | 10:46 PM
dabrogger
Guest
Posts: n/a
where can i find this mod?
Old Feb 22, 2010 | 10:55 PM
Potato_Potato
I am not sure but I think it is on a CVO Harley forum that was mentioned on this forum. I did a quick search but did not find anything.
Hopefully someone will chime in that knows.
Old Feb 22, 2010 | 10:57 PM
dabrogger
Guest
Posts: n/a
thanks for your help tp....i also searched unsuccessfully
Old Feb 22, 2010 | 11:05 PM
Potato_Potato
This could be it - I did not read all of the posts.
http://www.cvoharley.com/smf/index.php?topic=7674.0
Old Feb 23, 2010 | 06:36 PM
dabrogger
Guest
Posts: n/a
anyone else have any ideas on my problem short of buying a new deck? man, i miss my ipod!!!!
Old Feb 23, 2010 | 06:59 PM
frankh's Avatar
frankh
Default You can fix the aux jack
When my aux jack stopped working, I figured I had two choices: take it to the dealer, who would pull the radio out, send it off to be checked, and then who knows how many weeks later I'd get it back, maybe fixed under warranty or maybe I'd be paying; the second choice was to just fix it myself. I decided to just fix it.
I pulled the radio out, took off the front faceplate and found that the aux jack had come unsoldered. Two minutes later, after my soldering iron was heated up, the problem was fixed.
Since I was in there, and any chance of getting warranty work on the radio was gone because I opened it up, I decided to go ahead and do the add a jack in the back mod suggested in an earlier post on this thread. That post also describes how to open up the front of the radio to get to the aux jack.
Now, I have my Zumo plugged in to the new aux jack coming out of the back of my radio and have no more wires sticking out the front.
It wasn't brain surgery, but you need to have beginner soldering skills, and the courage to do something that might turn out great or might just turn your radio into a paperweight. It worked out well for me.
Old Feb 23, 2010 | 07:16 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
those aux ports are very fragile , and they are
Old Feb 23, 2010 | 07:19 PM
bigdumbnoitall00
that port is very fragile (got the exact same problem)it is NOT covered under warrenty ,saw the thread on add a jack and one on a place u can ship the head unit into and they will fix it as well as change out the hard to read screen and waterproof it .
Old Feb 23, 2010 | 07:30 PM
Retrax's Avatar
Retrax
I think you said your bike was a 99 (Pre Harmon Kardon) but you might want to give these guys a call and see if they can help...
http://www.ironcrossaudio.com/
springer 03
Audio Systems
Aug 3, 2013 08:16 AM
jjpish
Apr 3, 2012 08:24 PM
sanlyn
Mar 20, 2011 10:28 AM
jasnusc
Aug 23, 2010 09:29 AM
leadman
May 20, 2010 01:42 PM
