aux input port problems!! need help bad!!
Old Feb 22, 2010 | 07:18 PM
dabrogger
Guest
Posts: n/a
Default aux input port problems!! need help bad!!
Ok, I've used my Ipod plugged into the auxiliary port on my 99 flht forever and it's worked like a champ. Well, today, I installed new HogTunes tweeter pod only and, wow, what a great improvement!! I listened to it all afternoon with no problems. Here's my problem: tonight I went to show it off to a buddy and now it only sounds like maybe a quarter of the sound is coming out of the speakers, both the stock ones and the tweeter pod. This is ONLY when the Ipod is plugged in; the radio and casette sound great still. It's not the Ipod; I checked it in my truck. Does the little port thing go out or something? It seems like it's not making good connections inside or something. Oh yeah, I've tried two different cords too, so it's not the cord. Is there a way to wire the Ipod directly inside the head unit? I'm really upset and want my tunes back!
Old Feb 22, 2010 | 07:20 PM
Scooter-Dog's Avatar
Scooter-Dog
Did you accidentally turn down the volume on the iPod?
Old Feb 22, 2010 | 07:26 PM
dabrogger
Guest
Posts: n/a
nope, volume still up. it's like it's kind of distorted and squeeky sounding. i'm at a total loss. like i said, when i unplug the ipod the regular radio or the casette still sound awesome; just when the ipod is plugged in it sound awful!
justanotherjim's Avatar
justanotherjim
From: kingman AZ. We aren't in hell, but you can see it from here!!!
Is the pod fully charged?
Old Feb 22, 2010 | 07:30 PM
dabrogger
Guest
Posts: n/a
yep, pod fully charged. i recharged it and tried it again. the ipod works fine in my truck or on the computer or with the headphones...
Old Feb 22, 2010 | 07:39 PM
Jday53's Avatar
Jday53
sounds dumb but make sure its pushed all the way in and try turning the plug when you plug it in???
Old Feb 22, 2010 | 07:44 PM
dabrogger
Guest
Posts: n/a
tried turning it, pushing it, wiggling it, etc. this is really pissing me off!! thanks for the replies; keep them coming. certainly if anyone knows what the deal is, someone on here does....
Old Feb 22, 2010 | 07:55 PM
Bigfat's Avatar
Bigfat
Had a similar problem with aux port. Try a piece of tin foil wrapped around the plug and stick it in the port. Worked like a charm.
Old Feb 22, 2010 | 09:23 PM
Potato_Potato's Avatar
Potato_Potato
Try a different cable ?
Old Feb 22, 2010 | 10:32 PM
dabrogger
Guest
Posts: n/a
ok, tried different cables; still not workin. tried the foil trick; didn't work. after the foil trick though, i plugged it back in and well, when i pushed down on the cord, it worked perfectly as long as i kept a little pressure (down) on the cord. so, it's got to be something inside of the receptacle. like one of the little springy things that contacts the two parts on the cord is not making contact. now i've narrowed it down to that. is there any way to repair the inside of the port i.e. can the radio be taken apart enough to "respring" it? or, is there another port or something on the back that can be maybe "hardwired" in there? certainly, i don't have to buy a whole new deck just because the plug is messed up slightly? man, i hope not. i'll bet those decks are not cheap!!! any ideas on how i can just repair mine?
