Oil cooler adapter?
Old Mar 3, 2010 | 05:19 PM
Sancho's Avatar
Sancho
Default Oil cooler adapter?
Does anyone know what size allen wrench is needed to screw in the oil filter adapter into the adapter assembly on the HD Oil Cooler? A 3/8" is too small and a 1/2 is too big. Same with #10 metric and #12 metric.
I had to put a 1/2"'er to the grinder and make one that would fit.
Old Mar 3, 2010 | 05:20 PM
albatross's Avatar
albatross
I believe it's a 7/16"
Old Mar 3, 2010 | 05:25 PM
Sancho's Avatar
Sancho
Well I guess I have a home made 7/16" now. Try buying one of those where I live.
Old Mar 3, 2010 | 05:35 PM
jag1886's Avatar
jag1886
7/16 is hard to find I made one using an extra long 1/4" nut in a 7/16 socket. It worked perfect.
Old Mar 3, 2010 | 09:11 PM
V2Evo96's Avatar
V2Evo96
I hear you--- I made one out of a socket extension with a grinder to get mine installed....
jag1886 did it the right way-- I didn't have a nut that would fit the id though.
Old Mar 3, 2010 | 09:38 PM
niterider985's Avatar
niterider985
7/16 is the wrench size installed 3 and got it from the start.
Old Mar 3, 2010 | 09:51 PM
dirtdobber's Avatar
dirtdobber
I used a bolt with a nut run all the way on it then welded it. worked just fine.
Harbor freight carries a set for metric and sae at a low cost. Seems like the sets I got was $14 each
dd
Old Mar 3, 2010 | 10:51 PM
acftdr's Avatar
acftdr
Default 7/16"
I bought a cheap 7/16 allen wrench, cut off a portion and stuck it in a 7/16 socket. Worked great. I tried the nut and bolt trick but it was too tight.
Old Mar 3, 2010 | 11:39 PM
hog-doc's Avatar
hog-doc
Every Snap On truck has them!
homyakchik
Jan 6, 2019 07:21 AM
Highgrade
Jan 29, 2017 08:51 PM
keith t
Feb 20, 2011 11:31 AM
odie-in-az
Jun 6, 2009 04:56 PM
SPARKY01
Mar 21, 2009 10:30 PM
