road glide fairing
Old Mar 13, 2010 | 06:20 AM
manbug50's Avatar
manbug50
1st Gear
Default road glide fairing
just bought headlight trim to delete plastic shield and it doesnt fit. is there a diff between the 2010 and 2005 fairings?
Old Mar 13, 2010 | 07:14 AM
nedster's Avatar
nedster
I think the only difference is the angle of the fairing.
Old Mar 13, 2010 | 07:23 AM
Casper's Avatar
Casper
my 2010 doesn't have the plastic cover
Old Mar 13, 2010 | 08:19 AM
marvincbr's Avatar
marvincbr
That was one of the mods I added to mine over the winter. I did have to play with the headlight housing a little bit to get it to fit. It could still use a some adjusting to get the headlights centered in the openings better, but it does fit.
Old Mar 13, 2010 | 08:43 AM
Garemlin's Avatar
Garemlin
You are gonna have to adjust the headlights. Just went through this with mine. Best way to do it is take the outer fairing off and back the adjust screws out until it fits. If your headlights are already adjusted correctly then take a sharpie and mark on the screws in the same spot. Then back them out equal turns. When you get it to fit bring them back in until the point before they touch the bezel. You will know if you went too far because the bezel will pop out. It takes a little trial and error but it is pretty easy.
Old Mar 13, 2010 | 09:28 AM
knife_edge's Avatar
knife_edge
Are you having a problem with the trim not going in back enough to clip on? Because, I was having the same problem.... On my 2009, all I had to do is re-adjust the angle of the two screws on the bottom of the head light assembly and then it just snapped in just fine....
Old Mar 13, 2010 | 09:41 AM
sonar_chris's Avatar
sonar_chris
As others have said, if your head light adjustment screws are too far out, then your new trim ring will not snap in. Take off your outer faring and screw out the adjustment screws all and equal amount and try fitting the bezel again.
Old Mar 13, 2010 | 10:52 AM
shredsurf's Avatar
shredsurf
I recall mine just snapped in.
Old Mar 13, 2010 | 04:49 PM
manbug50's Avatar
manbug50
1st Gear
Thank you very much for all replys
Hdbkstl
2018+ Softail Models
Jan 10, 2019 06:31 PM
Upchuckg
Dec 27, 2015 11:18 AM
manbug50
Mar 13, 2010 07:06 AM
Shrug
Jan 22, 2010 11:31 PM
harley0711
Aug 9, 2006 06:26 AM
