Asked the H.D mechanic at my dealer about the frequent adjustments required. I thought it was the cable stretching from what I`d read on various forums. He said it was the cheap clutch that H.D. is using and it should stabilize after 10,000 mi. His guide is to adj. the cable about 10 times and then start the base adj. at the primary again. I`m easy on clutches and this one needs more attention than I`m used to.
They make a open socket set sold at sears or the ratchet wrench set with flex head that would be perfect for that but i would have no other use for it so i just use a open end wrench with no problem slipping or stripping. I like the dog bone idea and now i have a use for one. Always look at them just wondered what the hell i would use it for. Now i know.
Been doing the clutch adjustments so many years with the covers off almost don't remember.It is certainly no hassle.Once this adjustment is made always tweak at the cable adjuster anyway.
+1 important, I drain the oil hot and adjust the clutch the next AM. If you're having trouble getting the jam nut put it in gear and apply the back brake
Ya, what he said. Makes a huge difference, otherwise it shifts and your setting is not right. Surprised it never mentions this in the service manual. Come to think of it the service manual never mentions tips at all. Those **** types that write tech manuals must have a real sense of humor.
[QUOTE=Retrop;6543582]Ya, what he said. Makes a huge difference, otherwise it shifts and your setting is not right. Surprised it never mentions this in the service manual. QUOTE]
What are you saying happens if you adjust your cable right after draining fluid?? What's the huge difference?
As I was. Let me be a little more specific. Regarding the posters statement:
"If you're having trouble getting the jam nut put it in gear and apply the back brake."
By putting the transmission in gear and applying the rear brake it makes setting the jam nut much easier because the clutch basket does not turn when you put the 11/16" wrench or socket to it. This is not a big problem if the rear tire is setting on the ground but if the rear wheel is elevated on a lift, then it helps immensely to put the bike in gear and hold the brake when tightening the locking nut. I hope that clears this up. Sorry for the confusion.
What adjustment???
I've been adjusting it at the cable, I'm about 3/4's of threads gone
The next Primary change I'll re-index the cable ajustment and "reset" the nut..
Yes, I have plenty of wrenches That I'd love to bend or modify.....
I forgot all about this post......I never came back to thank you guys......the adjustment was a breeze and I ended up using one gear wrench's products.....I got a fairly large set at sears for short money.
