Smells like oil
Old Mar 23, 2010 | 07:28 AM
Sandcrab's Avatar
Sandcrab
Default Smells like oil
After riding my 09 Ultra, or when I pull up to a red light and no wind, I smell oil and it smells like transmission oil, which in my bike is Mobil 1 75W-90 gear oil. I have no leaks under my bike, checked the level best I could and it is ok, but I still have that odor. It's not a burnt oil smell, just an oil smell. Any ideas?
Old Mar 23, 2010 | 07:37 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Probably the blow by inside your air filter housing. Put your nose near it and I'm sure your smell it a lot stronger. Pull your air filter off and see if it's coated with oil. Common thing, keep your oil level a little lower on the stick and the problem should go away.
Old Mar 23, 2010 | 07:52 AM
BLKBAGGER's Avatar
BLKBAGGER
I have had the same problem before. It goes away after a long while. Gear oil stinks pretty good and if only a little is dripped on the outside of your motor it will be a stinker for what seems like forever.
Old Mar 23, 2010 | 03:34 PM
cookiemech's Avatar
cookiemech
On the 09 models it is nearly impossible to drain the transmission oil without spilling some on the frame cross-brace under the transmission. So if the area is not cleaned scrupulously, you'll smell gear oil for a long time.
Old Mar 23, 2010 | 03:39 PM
IAMSWUTIAMS's Avatar
IAMSWUTIAMS
the smell is probably coming out of the tranny breather tube. That's been my experience. It just went away after awhile.
Old Mar 23, 2010 | 04:10 PM
HDJIM1158's Avatar
HDJIM1158
I have the same condition with my 09, I hope it does go away soon. Be Safe JIM
Old Mar 23, 2010 | 08:14 PM
IAMSWUTIAMS
Abuse it, and it will stop. Ride it like you stole it.
Old Mar 23, 2010 | 08:44 PM
DPete's Avatar
DPete
Had the same thing, turned out to be the 2 bottom trans bolts were loose enough to leak a tiny bit but not enough to drip on the floor. Tightened all bolts, smell quit
Old Mar 23, 2010 | 10:50 PM
Mountainkowboy's Avatar
Mountainkowboy
Have the same smell on the EGC, really havent found the why yet. Will be checking it out more this spring. Notice it more on start-up when hot though.
LDR
Mar 20, 2026 11:21 AM
JW/SECO
May 25, 2011 08:33 PM
keith t
Apr 8, 2011 08:45 AM
truthfire
Apr 4, 2011 02:04 PM
1fathog
Oct 11, 2010 10:46 AM
