Electraglide stereo help!
Old Mar 30, 2010 | 09:52 PM
dabrogger
Guest
Posts: n/a
another thing, i could not stand the ipod cable sticking straight out of the front of my deck. so, i took the radio out, took it apart, and ran an auxiliary port out of the back and the little wire now comes out right at the hole where the clutch cable comes through the inner fairing; right where my ipod clips on the left mirror. much, much better. it should be noted that i know nothing about stereos, but found some good info with detailed pictures on how to do this mod. it worked like a charm.
Old Apr 1, 2010 | 11:09 AM
baggerz's Avatar
baggerz
Originally Posted by DTTJGlide
You need to get speakers that are compatible with the amp, I think the arc amp is most efficient with 2olm speakers & you need 8olm speakers for your radio, so I think you need to do both at the same time or you might do some damage. I have the same problem as mine is a 2000, I'd like to try just speakers, but if I go with 8olm & then later want to add an amp I think I'm screwed, I haven't got a good answer yet as most have the newer HK radio, still looking for better answers.
I have an 05 with the Radio Sound head unit. I ran the 2ohm J&M's with the Elf mini amp, factory head unit. Sounds great IMO.
Old Apr 1, 2010 | 03:17 PM
subdoc1's Avatar
subdoc1
Contact FIRECAP501 he will get you where you want to be and stands behind all he sells and does.
Love my ALpine with IPOD, HERTZ 165HCX 6.5", ARC 125.2 Mini amp, Hogtunes Tweeter pods and Hawgwired conversion kit.
System ROCKS!
Old Apr 1, 2010 | 05:27 PM
tj316's Avatar
tj316
i have an 01 flhtci , i put in the sony cdx-m60ui head unit, used hawg wired install kit , hawg wired double shot 150w amp and speakers and it rocks, it is on the high side but if you shop it, deals are out there
Old Apr 1, 2010 | 07:35 PM
jgreg65's Avatar
jgreg65
I have an 08 with the stock HK and aux port. It came with Hogtunes speakers and I upgraded to the 7.25 J&M and it is LIGHTYEARS difference WITHOUT an amp. I didnt want to draw too much power from the electrical system and I'm very happy. Maybe next year if I have nothing else left to mod or upgrade I'll do an amp. But let me tell you at 80-90mph the sound is still amazing and PLENTY LOUD. I got them from DR Vtwin. Hit the Sticky post on them you cant go wrong. And since your budget wise its a perfect first step that will last you as long as you want while your doing other mods.
Denver Dave
Audio Systems
Aug 22, 2013 01:41 PM
Vivid Glide 103
Audio Systems
Jun 21, 2013 07:21 AM
BFPhil
Audio Systems
Apr 11, 2013 06:37 PM
immusicman
Audio Systems
Dec 15, 2011 04:10 PM
davessworks
Jun 22, 2010 01:46 AM
