removing push rod covers?
Old Apr 9, 2010 | 07:02 AM
donf610's Avatar
donf610
Default removing push rod covers?
Im wanting to powder coat pr covers. Do heads have to come off? 07 streetglide
Old Apr 9, 2010 | 07:06 AM
cuda67bnl's Avatar
cuda67bnl
You'll have to take the rocker boxes off, or cut the push rods. Your choice.
Old Apr 9, 2010 | 07:08 AM
timvan's Avatar
timvan
get some ez install PR unless you plan on taking the top end apart...
May as well look into cams as well
Old Apr 9, 2010 | 07:13 AM
donf610's Avatar
donf610
I was going to remove rocker boxes as well, so pr will pull out of top without head removal?
Old Apr 9, 2010 | 07:27 AM
'05Train's Avatar
'05Train
When I did mine on the 'Train, I PC'd the tappet blocks too. We had to lift the tank, remove the rocker boxes, pull the pushrods out, remove the pushrod tubes and blocks, then put it all back together again. Do once cylinder at a time, and make sure you're at TDC on each of them, makes putting everything back together easier.
Old Apr 9, 2010 | 07:58 AM
cuda67bnl's Avatar
cuda67bnl
Yes......
Old Apr 9, 2010 | 10:24 AM
RK4ME's Avatar
RK4ME
Buy a HD Shop Manual before you start screwing around with the engine.
Old Apr 9, 2010 | 01:17 PM
donf610's Avatar
donf610
ok, thanx all
phananganang
Oct 13, 2013 03:57 PM
Alain
Dec 22, 2012 03:31 PM
jordanball33
Oct 8, 2010 07:22 PM
coze
Oct 14, 2008 03:03 PM
Dawg Rider
Oct 27, 2007 04:03 PM
