06 ultra SERT or PC111
Old Aug 11, 2006 | 08:14 PM
ricaroo's Avatar
ricaroo
Default 06 ultra SERT or PC111
I have an 06 Ultra completly stock. at start up if the bike is not 100% warmed up it coughs are may even stall when I start to let the clutch out in first gear. The dealer tells me thats the way it is due to the lean setting Which they can not change. So will a PC111 or a SERT solve the problem and if so will anything else need changing (additional parts A/C or pipes, I hope not)? Do I have the dealer install the PC111 or SERT?
When the bike is up to temp it runs like a top
Rick
Old Aug 11, 2006 | 08:19 PM
bountyhunter's Avatar
bountyhunter
Default RE: 06 ultra SERT or PC111
Should run like a top, right off the hop! Exhaust, air kit, PCIII & a qualifed tuner WILL improve performance dramatically.
Old Aug 14, 2006 | 01:10 PM
SSmike1's Avatar
SSmike1
you need to fix that
with a Power Commander 3 PCIII
or SERT
screaming eagle race tuner!
IF you get a PC3 it will cost you $500, and do it yourself.
if you get a SERT,
it cost $500 and $320 to have the dealer install it,
and Mibe still coughs when cold.
SO I HAD to do my OWN SERT install, to fix the Cold Engine Coughing!
Old Aug 14, 2006 | 02:26 PM
sligarn5's Avatar
sligarn5
Why $500.00?
Old Aug 14, 2006 | 02:32 PM
gunrunner's Avatar
gunrunner
ORIGINAL: SSmike1
or SERT
if you get a SERT,
500.00? no way, they are only 369.00 msrp form dynojet and
only 249.00- 269.00 everyday on ebay, free downloads for many applications on dynojet web site. but if its not right I would have the dealer fix it under warranty.
Old Aug 14, 2006 | 02:49 PM
mfalba's Avatar
mfalba
My stock '06 Softail did the same thing. Had the 8 degree injectors changed to the 25 degree injectors -- problem solved.
Old Aug 14, 2006 | 04:30 PM
henryjw1's Avatar
henryjw1
Check your injectors, you may need the 25s.
Old Aug 14, 2006 | 05:14 PM
06 roadglide's Avatar
06 roadglide
Got my PCIII From eastern performance $ 277.00 shiped to my house.
Old Aug 14, 2006 | 09:16 PM
dgriffith's Avatar
dgriffith
I went through this problem with my bone stock 06 ultra, and with the new E C M updates it helped a little, then I had the High Flow filter kit& reprogram ,It runs a lot better. Mine would cough and backfire when it was hot or cold. try that when you are going around a corner from a stop!!!!!! After the first day of having it done it has not offered to do it again. It seems like it picked up another 20 HP. It sure sounds a lot different.
Fairbank12
Jan 27, 2015 09:25 AM
TBinTX
Feb 2, 2013 03:00 PM
wildrider
Aug 10, 2008 02:32 PM
ebeattie
11
Jul 21, 2007 10:45 PM
elvis8
Apr 21, 2007 11:25 AM
