Acc switch on 02 E-Glide
Old May 13, 2010 | 08:19 PM
GzrGlide's Avatar
GzrGlide
Default Acc switch on 02 E-Glide
I just spent the last couple hours searching threads and posts for this answer, but haven't found anything definitive.
Can somone say for sure whether or not the acc switch on the dash panel is prewired to a hidden plug?
I'm using the usual acc plug from under the seat, by the battery, to run the LED spoiler lights on the tour pak and saddlebag lids. This plug is not controlled by the acc switch. Is it just a dead switch? Or is there another plug hidden somewhere on the 2002 Glides?
Old May 13, 2010 | 09:03 PM
Punjabi Rider's Avatar
Punjabi Rider
Not sure for 02 but 08 has an outlet near battery which I used to plug in heated hand grips on my wife's Ultra for easy on off function not much help for your specific model year sorry.
Old May 13, 2010 | 10:30 PM
GzrGlide's Avatar
GzrGlide
Yes I know all you guys with the "newer" bikes have that famous plug and switch setup. But I need to know specifically for the 02 vintage bikes. I think they changed the setup around '04, but I'm not sure.
Old May 13, 2010 | 11:43 PM
Harleypingman's Avatar
Harleypingman
The ACC connector under the seat that you are using for the spoiler LED's uses only three of the four wires in the connector. The fourth wire is for the switched circuit controlled by the ACC switch on the switch cap. The ACC connector has ground, run, and brake light circuits that are not controlled by the ACC switch.
Carl
Old May 14, 2010 | 12:43 AM
GzrGlide's Avatar
GzrGlide
OHHHHHH!!!!!! Now that makes sense. I'll have to check it out tomorrow night.
So, if I added another splitter/y-connector to the one I'm already using to run the LED spoilers, and plug in the accessory to the open plug of the second splitter, the acc switch should work for the new accessory?
Saying it another way.....
Splitter 1 plugged into bike's acc plug.
Plug A on Splitter 1 gets Splitter 2 plugged into it.
Tour Pak and Lid Spoilers plugged into the 2 plugs on Splitter 2
Plug B on Splitter 1 is now open for new accessory that can be turned on/off with acc switch!?
Did I get that right?
Old May 14, 2010 | 08:35 AM
Harleypingman
Yes, you can do as you described. On my bike, I didn't use the tour pak spoiler LED Deutsch connector; instead, I simply spliced the spoiler LED wires to the wiring harness in the tour pak that the side marker lights and rear run/brake lights use. Since my tour pak is detachable, wiring it this way made for one less electrical connection to disconnect/connect when removing/installing the tour pak, and since the lid is drilled for the spoiler, I wasn't concerned about being able to remove the spoiler LED from the tour pak in the future.
You can also add a wire for the switched circuit to one of your existing connectors (and a ground if necessary) rather than add another Y-splitter.
Carl
Old May 14, 2010 | 11:21 AM
tj316's Avatar
tj316
harleypingman is correct, i have an 01 and the plug under the seat is connected to the acc switch
Old May 14, 2010 | 03:23 PM
HDRider2002's Avatar
HDRider2002
Plug under the seat was connected to the ACC switch on my 02 Road King
Old May 14, 2010 | 05:05 PM
GzrGlide's Avatar
GzrGlide
Very cool. Thanks folks.
Old Jul 25, 2010 | 10:16 PM
YtseJam's Avatar
YtseJam
Can someone take a picture of the ACC "plug" under the seat? I would like to use it to control my LED's.
Jfogle01
Mar 26, 2019 07:42 AM
kurt84
Jul 31, 2012 12:47 AM
jay87LX
Apr 10, 2012 10:29 AM
Hrlyrider
Dec 28, 2008 09:17 PM
cooper57M
Mar 10, 2008 07:30 PM
