HD Inner Primary Soft?!?
Old May 18, 2010 | 08:26 PM
Yachtman's Avatar
Yachtman
Default HD Inner Primary Soft?!?
About a year and a half ago I had a new HD Inner Primary installed at the dealer and have had three issues with bolts stripping since. The starter bolts stripped after being reinstalled a second time from a inner shaft leaking. Today I had the outer cover off and when I reinstalled it, the number 5 bolt stripped. And with barely more than 9 nms on the wrench, as per the manual. Sucky crap materials. Threads from the primary came right out on the bolt when I backed it out. I put the bolt back in with some plumbers tape, but still it wants to spin.
So with any luck the number 5 bolt area wont leak (? !!) but either way I have to get another inner.
Please, anyone with a good suggestion on where to buy one that's made with harder materials, I'd appreciate the info.
Thanks!
Old May 18, 2010 | 08:31 PM
Hrlyrider's Avatar
Hrlyrider
replace with a chrome one and use locktite and don't crank as tight
Old May 18, 2010 | 09:46 PM
Yachtman's Avatar
Yachtman
It is a chrome inner! And I really didn't crank on it. I tightened it to HD Manual Specs!
Old May 18, 2010 | 10:06 PM
Bill03E's Avatar
Bill03E
put a heli-coil in, and be done with it, it will be stronger than the parent material.
Old May 18, 2010 | 10:44 PM
sifularson's Avatar
sifularson
You can also tap out the hole to the next size, drill the cover and put a new larger bolt in that hole. Doubt anyone would even notice. Much simpler than putting a heli-coil in that hole.
Just my 2 cents.
Old May 18, 2010 | 10:45 PM
stro1965's Avatar
stro1965
I really like heli-coils. I had to use two of them on my outer primary when my derby cover bolts brought the threads out with them.
Old May 18, 2010 | 10:48 PM
FX4's Avatar
FX4
I would also check your torque wrench. May be quite a ways out of spec.
Old May 18, 2010 | 11:59 PM
monenypitof07's Avatar
monenypitof07
Unbelieveable taste in Motorcycles....nice bike.
Old May 19, 2010 | 12:53 AM
hog-doc's Avatar
hog-doc
yep!!
Old May 19, 2010 | 12:55 AM
hog-doc's Avatar
hog-doc
Just my 2 cents.
NOPE!!
Heli-coil it, keep the correct size fastener. Wont have to deal with to small a lip around a 5/16" hole in the cover, enlarging the gasket hole and reducing the sealing surface area. Just fix it right with the heli-coil, it will be stronger than before!
