Dyna Beads Question?
Old May 21, 2010 | 11:43 AM
Spur56's Avatar
Spur56
Bama,
5 ozs is a lot of weight and you are probably correct. Dyna beads will tell you to leave the weights on your tire if it takes a large amount of weight to balance. They cannot compensate for that much. I would also get that rim checked out for tightness and truing of the spokes.
I actually left the weights on my tires with the dyna beads and it is smooth as glass.
Old May 21, 2010 | 12:33 PM
huffhuff's Avatar
huffhuff
Originally Posted by Alabamaslammer
I just changed my tube and got the wheel high speed balanced. It took 5 ozs. of weights to balance it, The rim must be out a bit. Must of been to much for the beads to balance. Hopeing for a smoother ride now
i would move the tire 180 degrees on the wheel. that may cut the amount of weight needed. i would also balance the wheel first without the tire and tube. assemble then balance again.
Old May 21, 2010 | 12:43 PM
will2002's Avatar
will2002
UPDATE! ...I put 2 oz in rear tire and 1 oz. in front tire and rode the bike. Not exactly where I thought it should be..... Added one oz. to the front tire. ....Smooth a wet ice, and I'm a happy rider!
Old May 21, 2010 | 01:37 PM
Roadie09's Avatar
Roadie09
This is where I am running the beads (2oz. front, 2oz. rear). Just cut the bag and dump them in the unmounted tire before mounting it on the rim. Last go around I feed them through the valve stem, what a pain that is.
Old May 21, 2010 | 01:50 PM
captjon37's Avatar
captjon37
keep in mind when mounting the tire (if you do your own) not to get too sloppy with the tire mounting lube (ruglyde for me). The inside of the tire needs to be dry for them to work properly.
Rusty19MCSFV
The Dark Side
26
Aug 30, 2016 04:35 PM
bigskyroadglide
Mar 21, 2012 11:12 PM
pacificrider
Jun 30, 2010 01:50 PM
Ronp42
Feb 25, 2010 09:29 AM
08Fatty
Jul 30, 2009 07:55 AM
