fork grease zerk
Old Aug 25, 2006 | 11:27 PM
Nomadic RAM's Avatar
Nomadic RAM
Default RE: fork grease zerk
ORIGINAL: roady
I just greased mine today with the straight fitting with no problem. I didnt think it would ever stop taking grease though. It took a good forty to fifty pumps before I started to see any grease comming out. I guess the factory missed and the dealer during the 1000 mile service.
You'll be sorry you dumped that much grease into the steering head. I predict it'll puke grease out the bottom of your bearing each time you ride for the next several months. A couple pumps is all it ever needs. I learned this the hard way - just as you are about to do.
Old Aug 26, 2006 | 12:09 AM
dawg's Avatar
dawg
ORIGINAL: Nomadic RAM
ORIGINAL: roady
Great[] I just posted in another post about mine taking about 50 pumps or so to get the grease coming out. Oh well I'll just keep an eye on it.
Old Aug 27, 2006 | 03:04 PM
cwilks's Avatar
cwilks
ORIGINAL: roady
That's great info, just getting ready to do mine.
Old Aug 27, 2006 | 03:36 PM
ricaroo's Avatar
ricaroo
I called harley tech in WI. and told them I had to pump a ton of grease into the fitting until it started to come out at the top and bottom of the neck (as indicated in the service manual) then I stoped. I ask why so much grease and they told me at the plant they grease the bearings as the front end is being assembled and when the 1000 mile service is done it takes a lot of grease because you are filling the entire neck. Well anyway I have put almost 3000 miles and the grease isn't coming out no problem here.
Old Aug 27, 2006 | 06:59 PM
BigTinVA's Avatar
BigTinVA
ORIGINAL: roady
Roady,
How the heck did you get your grease gun tip on to that straight zerk??? My 04 Road Glide had the straight zerk and there was no way in hell that I could get a grease gun on that fitting, even with a 90° grease gun tip. It was all up in the bracketry for the fairing. I had to change mine out to a 90° zerk.
Old Aug 31, 2006 | 12:10 AM
Grover's Avatar
Grover
Administrator Emeritus
90 degree zerk 75 cents
Tube of grease $2.00
5 minutes time no charge
MAKE SURE THE JOB IS DONE RIGHT ---- PRICELESS!!
Old Sep 1, 2006 | 03:01 AM
dforeid's Avatar
dforeid
Heard same as mentioned earlier, bearings are greased at the factory, but the neck isn't filled - that's why it takes 40 or so pumps the first time it's greased. Mine did the same. I've had no grease weeping problems at all. Word of warning, I was told to use only the HD grease that is called for as it's a different formula than other greases and will resist weeping out on hot days. Don't know how true that is, but that's what the dealer and an Indy told me. I went with what HD spec'd and have had no problems.
6speed
Apr 24, 2021 05:18 PM
bellgnte
May 24, 2016 10:04 AM
Jim Kraft
EVO
Nov 15, 2013 04:18 AM
Turret_plug
Sep 1, 2012 03:54 PM
Keithhu
May 15, 2012 07:54 AM
