TBW issues and Apes.
Old Jul 4, 2010 | 10:06 AM
Springerfan's Avatar
Springerfan
Default TBW issues and Apes.
I keep hearing about issues with the "green" connector coming apart and generally causing nightmares when trying to route wiring through the bars. So fo those that have been through this, what is the best way to avoid these issues. I apologize if there is already a thread on this but I couldn't find the specific info. on a search.
Old Jul 4, 2010 | 10:24 AM
PistonPuller's Avatar
PistonPuller
I wrapped mine with electrical tape. Didn't have any problems at all.
Old Jul 4, 2010 | 10:31 AM
Oldman Harley's Avatar
Oldman Harley
There are several companies including Harley that make wiring kits that don;t have the green connector in the handlebars. Maybe Dawg can chime in with the HD part #
Tim
Old Jul 4, 2010 | 11:19 AM
qtrracer's Avatar
qtrracer
Talking
The one good thing about running wires inside the bars is that from that time forward whenever you have electrical problems(and you will eventually) you will know EXACTLY where to look, the internal wiring inside the handlebars!!!!!
Old Jul 4, 2010 | 12:12 PM
BQsHX's Avatar
BQsHX
Default TBW extension
I just cut one end off of the extension and cut the other end of the TBW section, soldered it, insulated it and pulled it through the bars. The cruise, signal, stereo control wire bundle leaves very little room for the green plug to be used. We tried the install with the green plugs (taped together) and we still managed to pull them apart. Didn't know we pulled them apart until we tried starting the bike and got a flashing cruise light and no throttle response.
Old Jul 4, 2010 | 12:20 PM
flight's Avatar
flight
Heat shrink tubing
Old Jul 4, 2010 | 02:09 PM
glide2005's Avatar
glide2005
I just installed 16" apes on my EGC this weekend and used srink tubeing on everything. Let me say this, its hard to stuff 2 lbs of wire thru a 1 lb hole. It couldn't have been done without a jar of vasoline. Job complete and everything still works. I was sweating bullets on this one. After you splice 12" of wire, it makes a pretty good sise bundle to pull thru. The srink tubeing realy works good.
Old Jul 4, 2010 | 03:30 PM
roadgliderick's Avatar
roadgliderick
i also soldered my TBW this way it wont come apart. and yea i was sweating bullets also but everything came out alright. i bought the novello strech kit + 12
Old Jul 4, 2010 | 03:34 PM
dawg's Avatar
dawg
If internally wiring bars, use 32310-08 which is the TBW sensor specifically designed for this without the green clip.
Old Jul 4, 2010 | 04:32 PM
_YT_'s Avatar
_YT_
3rd Gear
That's a great idea BQ! Then by doing that you save room and it makes it easy to get the bundle through...
purpledeuce
Milwaukee Eight (M8)
Jul 10, 2017 11:15 AM
smokinfromshootin
Nov 20, 2010 09:01 PM
ex ninjadude
Oct 13, 2010 11:31 PM
Big Green
Jun 27, 2010 10:31 PM
ACE75
Nov 8, 2006 09:24 PM
