Remove heel shifter?
Old Aug 26, 2006 | 10:39 PM
hangnman's Avatar
hangnman
Default Remove heel shifter?
Is this easy i hate mine!
Old Aug 26, 2006 | 10:47 PM
bountyhunter's Avatar
bountyhunter
Default RE: Remove heel shifter?
Easy!
Old Aug 26, 2006 | 10:48 PM
wnogood's Avatar
wnogood
YES! I wear a size 13 boot and my foot will not fit between the heel-toe. Harley makes a chrome cover to go over the shaft that will be empty when you remove the heel portion. Kuryakyn ( I think ) makes a spacer to let you move the toe out where the heel use to be. I have the Harley chrome cap. Works great!
nogood o~`o
Old Aug 26, 2006 | 10:49 PM
wnogood's Avatar
wnogood
Thats the Harley cap. Thanks BH.....
nogood o~`o
PhilM's Avatar
PhilM
Piece of cake.
Kuryakyn makes a "shim" that you can slide in place of the inner (rear) shifter or HD sell a cap for the end of the shifter shaft, but you have to slide the toe shifter in and then place the cap on hte outside.
I've always removed mine and replaced the toe shifter with an EZ-Brake Long shifter. It's awesome!
[IMG]local://upfiles/8665/814E3977DC0B4C27A5A71D2483CADE1F.jpg[/IMG]
Old Aug 26, 2006 | 10:51 PM
PhilM's Avatar
PhilM
Wow , 4 replies in 2 minutes!
Old Aug 26, 2006 | 11:05 PM
wnogood's Avatar
wnogood
Yeah, we all jumped on that one! Must be a popular modification...
nogood o~`o
Old Aug 26, 2006 | 11:13 PM
gunrunner's Avatar
gunrunner
Harley has two versions, the cap only, just remove back lever and it cover's the shaft, 12.95, and the other one that includes a spacer so you can move the front shifter out and a cap, it costs 24.95, but i prefer the front shifter in original position so the 12.95 worked great.
Old Aug 26, 2006 | 11:28 PM
blackend's Avatar
blackend
[sm=smiley9.gif]I see this problem alot! is there a co. that can set up a size 13 rider with a longer ..shifter (I almost said shaft!!!)
Old Aug 26, 2006 | 11:30 PM
PhilM's Avatar
PhilM
ORIGINAL: blackend
Look at my post above....
www.E-Zbrake.com
