Air temp Gauge?
Old Jul 18, 2010 | 06:44 AM
binkman78's Avatar
binkman78
Originally Posted by mike5511
Had them remove mine and replace with oil temp gauge before I took delivery. Still can't figure out why HD thinks it is a good idea to put that useless air temp gauge on their bikes??????
Mount the lil white sensor box on the outside down tube, mine is very accurate - I really only watch it in Winter......my 0.02 cents.
Old Jul 18, 2010 | 07:08 AM
Jim Dawson's Avatar
Jim Dawson
Mine works fine. If I replace it with an oil temp gauge and don't like the oil temp, what can I do about it anyway? I can't change the oil temp any easier than I can change the outside air temp.
Old Jul 18, 2010 | 09:08 AM
Rottiman's Avatar
Rottiman
From: Ontario, Canada home of the TAX YOU TO DEATH LIBERALS
Simple, it probable cost the MOCO ten bucks for the air temp hole filler, and then they can soak you a hundred and thirty four bucks to replace it with the oil temp kit....................More innovative MOCO marketing @ work.
Old Jul 18, 2010 | 01:15 PM
mike5511's Avatar
mike5511
That really is the only explanation that makes sense.
Old Jul 18, 2010 | 01:20 PM
mike5511's Avatar
mike5511
You could install an oil cooler, an oil cooler with a fan kit, or take advantage of the many tuning options out there that will let your motor run cooler. In the event your motor was beginning to run hot, and you were stuck in traffic or something, your oil temp gauge would tell you things are heating up and you could shut your motor off before any harm could occur. The way you take of a motor plays a big part in how long it will live.
Old Jul 18, 2010 | 04:56 PM
Retrop's Avatar
Retrop
I am curious as to where you found the "lil white sensor box" located at. I have looked at doing this several times but can never find the sensor. It must be hidden pretty good.
Old Jul 18, 2010 | 05:09 PM
hawg08's Avatar
hawg08
You'd be better off just to leave the light out of it for all the good it does. Three words: oil temperature gauge!!
Danny D
Jan 14, 2014 11:40 AM
Lilman
Jun 26, 2010 06:25 PM
HEYENG
Mar 23, 2009 08:32 AM
clap
Mar 9, 2009 07:14 AM
soos
Dec 25, 2006 07:09 PM
