I doubt anyone is tearing down a crate motor, might as well buy the kit at that point.
I would. It's way to easy to pull the heads off a motor on the stand and check deck height. Also be easy to correct it at that time rather than deal with it later when chasing tuning issues and/or low power.
JMO
Zach
Will the builder check deck height automatically on the "KIT" during assembly?
Thanks for the input. I'm a little surprised that they would not use there roller tappets but thats why i asked. There not listed as a part of this motor in the SE catalog.
Thanks again,
they used roller "tappets" lifters.if your talking about roller rockers. no they didn't use them.do you think roller rockers are necessary? why?
Probably depends on the builder. I have my doubts if a dealer tech would check it. Probably not in the install instructions and even if he did check it, they weren't being paid to correct it if it was off.
If a performance oriented indy shop was assembling it for you..... probably (I hope).
