iPod interface
Old Aug 23, 2012 | 10:46 AM
  #191
davessworks's Avatar
davessworks
Originally Posted by UltraNutZ
got a cable long enough to go into the tourpak on 2012 flhtk? I don't want to fool with the saddlebag installation.
Piece of cake. The same cable for the saddle bag is easily long enough for the tourpac. All you need to do is remove the right hand side gromet and enlarge the hole (in the gromet not the tourpac!). The cable will pass through with no further mods. Then you can bring the cable up past the liner next to the 12v outlet without cutting the liner. I ended up buying the saddlebag mounting pouch and modifying it so it would mount on the two bolts that secure the passenger back rest. To do this I had to buy longer bolts and use a nut to secure the back rest and an additional bit to secure the pouch. I'll take some pictures and post when I have a chance.
Old Aug 23, 2012 | 12:52 PM
  #192
UltraNutZ's Avatar
UltraNutZ
that would be greatly appreciated sir.
Old Aug 23, 2012 | 01:11 PM
  #193
davessworks
Please bear in mind that my comments apply to all Harley cables, not after market, although these may also work.
Old Aug 23, 2012 | 03:02 PM
  #194
Airborne350G's Avatar
Airborne350G
Those with the Harley iPod interface. Has anyone used an iPhone instead of an iPod? Does it keep the phone charged and operate it like an iPod?
Old Aug 23, 2012 | 03:09 PM
  #195
Tortoise98's Avatar
Tortoise98
Yes it will
Old Aug 23, 2012 | 03:52 PM
  #196
davessworks
Note that the original holes line up almost exactly with the backrest bolt spacing. You have to bend the metal rail of the pouch (there's a steel rail that slides in a pocket on each side of the pouch) on the right side in a little (dog leg) to ensure that the eye of the teather of the TourPac lid can freely rotate). I let the other side of the pouch just sit inside the TourPac - but I threaded a Velcro cable tie down strap "hooks down" and it catches the liner material really well. It's not necessary but it works.
Old Aug 23, 2012 | 04:06 PM
  #197
skratch's Avatar
skratch
Originally Posted by shortcircuit62
yeah, that's the onthemovetechnologies one, same as sold by iron cross, and is going for more than iron cross sells it. for something like that, i would stick with a reputable seller, that i know i will be able to get some tech support if needed.
Old Aug 23, 2012 | 04:47 PM
  #198
Airborne350G
So does the iPod interface come with a cable that will reach the tour pak? Or do you have to spend another $100+ bucks on the saddle bag Kit?
Old Aug 23, 2012 | 06:00 PM
  #199
PhotoRider's Avatar
PhotoRider
Man talk about $$$$ just to control an IPOD. I priced the HD out about almost $500. I bought a complete radio with GPS and touch screen for my truck for $699. It came with an IPOD interface, blue-tooth to connect up to a phone (internet radio ready) and a flash card interface. Why should a IPOD interface be almost the same...
For that money I just bought a Road Tac with the mp3 player and Sirius radio. it was only $700 with cable to connect up to the radio.
Old Aug 23, 2012 | 06:42 PM
  #200
In2It's Avatar
In2It
Onthemovetechnology is the manufacture of thelucky HDPDPLUS and the revamped pdplus2.Iron cross is a resaler as others out there such as easternperformance.
