Oh no not another handlebar thread.......need more pullback.
Old Aug 9, 2010 | 03:37 PM
DrPlastic's Avatar
DrPlastic
Default Oh no not another handlebar thread.......need more pullback.
Ok now bear with me here. I have searched but I always come up on dead ends concerning what I am looking for. I have swapped out my stock bars with a set of KW +2 wide sweepers. I did the internal wiring thing also and installed a +4" Diamond back clutch cable.
I am looking for a set of bars that have the same width and wrist angle as stock just more pullback in CHROME. I know HD sells a set of touring pullbacks but they are not chrome. Anyone with any constructive input to this? I like the KW's but they are significantly wider and negate the extra pullback.
TIA
Old Aug 9, 2010 | 07:01 PM
DrPlastic's Avatar
DrPlastic
Someone has got to have an answer to this one!!
Old Aug 9, 2010 | 07:37 PM
Oldman Harley's Avatar
Oldman Harley
Check out the Flanders Bars. These are the bars I am using on my 08 ultra. 2 inches taller and at least 2 inches more pullback, I think it is more like 3 inches pullback but judge for yourself. http://www.sideroadcycles.com/Americ...lassic2-2.html They are also the stock width of 31 inches.
Tim
Old Aug 9, 2010 | 07:41 PM
All Aces's Avatar
All Aces
Not an answer but a question. I am looking at the same as what you have now for my 2010 EGC. Is the only thing you didn't like is lack of more pullback? How tall are you. I am 6ft and looking for a little more pullback but wider than stock.
Old Aug 9, 2010 | 08:59 PM
DrPlastic's Avatar
DrPlastic
If you are asking me this question then yes I am looking for more pullback. I am 5'4". The KW bars wound up being a bit wider than I like.
Old Aug 9, 2010 | 09:35 PM
pettifogger1's Avatar
pettifogger1
I had the same problem. Installed the KW bars and didn't like the extra width. Bought Harley bars 56176-08. They are polished stainless steel and look fine. They were much easier to run the internal wiring because of the way the wiring slots in the handlebars are cut. (The KW bars took hours, the Harley bars minutes.) They are the same width as the stockers, but a little higher and further to the rear. Just got back from a 3,000 mile trip to Yellowstone and the bars were great.
Old Aug 10, 2010 | 04:52 AM
DrPlastic's Avatar
DrPlastic
Problem is I want chrome, not polished SS! There is a difference in the finish.
Old Aug 10, 2010 | 08:12 AM
CADguy's Avatar
CADguy
Maybe call KW's and see if they will custom bend you a set? Maybe some +4? I'm am willing to bet that it would be a couple clicks on the computer and that the bars are CNC bent. Just a thought.
Old Aug 10, 2010 | 08:21 AM
pettifogger1
Out in the garage side by side you would be hard pressed to tell the difference in finish between the KW and the HD.
Old Aug 10, 2010 | 08:27 AM
RFG7680's Avatar
RFG7680
I cant help ya with new ones but I'll buy the +2's. Part number is 300515? Good luck in your search.
