Shifter spline
Old Sep 30, 2010 | 11:16 AM
cf3go's Avatar
cf3go
Default Shifter spline
Anybody know what spline it is for the shift lever? sae j500 1/2-36? Making my own shifters and want to know for sure b4 I order the broach.
Thanks for any input!
Old Nov 15, 2012 | 03:28 PM
dsb13's Avatar
dsb13
I'm in the same boat now as I'm making a set for myself.....did you ever get an answer to your question?
Thanks
Old Feb 29, 2020 | 03:29 AM
josame's Avatar
josame
I had to replace my shaft and arm on my 16. I was told when I bought the replacements the they were up graded parts, I'm pretty sure this is a pretty common problem with the 2016's, not from stomping... One thing while tightening the bolt I found it hard to get enough torque on it using an allen wrench, Use an allen that you can put on your wrench to get to the proper torque.
Old Feb 29, 2020 | 03:45 AM
packmen21's Avatar
packmen21
+1
Old Feb 29, 2020 | 09:54 PM
Zerk's Avatar
Zerk
I put anti seize on the bolt, it acts as lubricant increases tq around 10 %. My belief us it lets you crank harder with less chance if stripping.
Old Mar 1, 2020 | 01:21 AM
dickey's Avatar
dickey
I have absolutely no idea what this person is asking.
Old Mar 1, 2020 | 05:44 AM
Keithhu's Avatar
Keithhu
I would assume that 10 years after the original post he probably figured it out.
Old Mar 1, 2020 | 09:17 AM
Zerk's Avatar
Zerk
the dimensions or whatever you measure splined shafts by. Probably not sold by small, medium, large.
Old Mar 1, 2020 | 02:24 PM
Circa58's Avatar
Circa58
diameter x spline grooves in 360 degrees
Old Mar 2, 2020 | 02:05 PM
CarlosGGodfrog's Avatar
CarlosGGodfrog
Did you ever find the broach dealer ? I'm in Menomonee Falls, Wi.
