Heated grips problem
Old Apr 28, 2013 | 04:00 PM
bill1nat's Avatar
bill1nat
I have an 08 Ultra classic that did not come with heated grips. After much research i purchased and installed a pair of Heat Demons heated grips with chrome switch. I have had them for 1 year now without any problems. I was a little nervous about the install with the throttle by wire, but there customer service was awesome and they talked me right through it. just my 2 cents
Old Apr 28, 2013 | 04:03 PM
Pete6114's Avatar
Pete6114
Knock on wood, mine still work but the right grip gets noticeably warmer then the left.
Better then nothing, but I'll never replace them at my cost. I'd much sooner get heated gloves.
Old May 11, 2013 | 07:05 AM
Twinrider's Avatar
Twinrider
After my 2nd set of OEM heated grips crapped out on me I installed a set of Heat Demons. They produce a lot of heat. The 4-led light indicator for heat level is very convenient at night and a nice improvement over the OEM in this respect.
The only downside to these is that you have to cycle through the higher levels to turn it down or off, and if you shut off the motor you need to switch the heated grips on again when you resume riding.
All in all very pleased with these and web research indicates that they are very reliable.
Old May 16, 2013 | 09:59 PM
kuszman603's Avatar
kuszman603
6th Gear
Default Heated Grip Problems on FLHTK / Heat Deamon Grips
I have a 2011 FLHTK and the heated grips went out just after the warranty expired and I did not buy the extended warranty. In the typical poor quality Harley Customer Service style they refused to replace the grips even though they went out about a month after the warranty expired. I asked a Harley mechaninc if I bought new grips how long he thought they would last and he said he would not waste his money on factory grips. He said he installed Heat Deamons on his and he loves them. He said they are built to last and they are wired differently than the Harley grips so they will probably last much longer.
Has anyone installed the Heat Deamons and how do you like them?
Old May 17, 2013 | 08:35 PM
Twinrider's Avatar
Twinrider
Read my post above yours....
Old May 17, 2013 | 09:10 PM
Scooby-Doo's Avatar
Scooby-Doo
6th Gear
2013 ultra ltd 1000k miles. Brought it in for service. Yep you guessed it heated grips not working.. Do I really care, living here in Texas. Well Hell ya stand behind your product HD your selling crap We all know it. Tuesday new ones being installed. We ought to start a poll to see how many have been replaced.
Old May 18, 2013 | 07:03 AM
bill1nat's Avatar
bill1nat
I love my Heat Demons
Old May 18, 2013 | 12:41 PM
OldPhat's Avatar
OldPhat
It means you can not run the wires through the handle bars
Old May 18, 2013 | 02:05 PM
Sagido's Avatar
Sagido
I had the HD Heated Grips installed on my 09 Ultra Classic, and never had an issue. On my 13 Unltra Limited, the one connector was routed improperly and came loose, havent had an issue since.
Old May 19, 2013 | 05:36 AM
BikerPaul's Avatar
BikerPaul
I couldn't keep harley grips working on my '04 EGC, put on Heat Demons and love them!
PopsHD
2014-2024 Touring Models
17
May 5, 2018 03:15 AM
Rampant
Nov 3, 2014 10:58 PM
Carbo
Feb 26, 2013 10:28 PM
skygayt
Electrical/Lighting/Alarm
Oct 26, 2012 05:00 PM
cdestuck
Sep 18, 2010 12:20 PM
