New tour pack hinges.
Old Nov 7, 2010 | 07:52 AM
MassHD's Avatar
MassHD
Originally Posted by ThunderBueller
Yep, drill out the rivets and bolt on the new ones. Piece of cake.
I read some a thread where a guy dremeled off the end inside the pac. That will eliminate the drilling. Some like a good idea to me. I have them on the list this winter.
Old Nov 7, 2010 | 09:18 AM
ThunderBueller's Avatar
ThunderBueller
I had to drill anyway, the holes were too small for the hinge bolts. Just barely.
Old Nov 7, 2010 | 09:29 AM
2011FLHTK's Avatar
2011FLHTK
Thanks for the info and pics. Going to get a pair.
MSgt Rose's Avatar
MSgt Rose
I like them too, will add to my winter "to do" list. Thanks to those of you who posted pics, really helped in making my decision.
Old Nov 7, 2010 | 09:52 AM
frenchbiker's Avatar
frenchbiker
You're welcome. By the way, plan to have a helper when you install them. Someone has to hold the lid while you're mounting the screws thru the new hinges. Tough to do with only 2 hands.
Old Nov 7, 2010 | 10:05 AM
Punjabi Rider's Avatar
Punjabi Rider
Are those made of steel or same material as regular latches which are easy to break about every 25 to 30k miles or so.
Old Nov 7, 2010 | 10:43 AM
frenchbiker
They're made of steel, and they're much more sturdy and heavier than the flimsy stock hinges.
Old Nov 7, 2010 | 10:49 AM
mtclassic's Avatar
mtclassic
I did not have any help and it was not a problem. If you hook up the tether line and attach the latch to the lower portion first. I then just set the top on in an open postion and it stayed in place while I screwed in the top screws.
It would have been quicker using a dremel I think because all you are doing is grinding down the end of the rivet so it can pop out.
Old Nov 7, 2010 | 10:53 AM
Buzzsaw's Avatar
Buzzsaw
If you do a search there are a few threads on installing this and the tricks to help out, including what size drill bit to use to make it easier to install...I know I found it helpful when I installed mine. I do think they are more solid and look a good bit better...
Old Nov 7, 2010 | 11:18 AM
Slash's Avatar
Slash
Maybe I need to see these premium hinges in person....Went out to the garage and looked at my FLHTCU and can't imagine it looking right if I changed...
The premium hinges appear to be more sturdy,looks like there's about 2 1/2 times more metal to 'em....the hinges appear to be larger than the actual latches on the other side of the TourPak.
Would probably be too much chrome on the side of the box for my taste,but like I said,gonna need to see 'em in person.
